Results 1 to 4 of 4
    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    A bunch of power train data bus codes?
    Hello, I now am getting a bunch of power train databus codes and I'm stumped. I replaced the fuel pump relay with a cheap one from oriellys not sure if that could be the culprit. The codes I am getting are as follows:
    ENGINE
    18107 power train databus: missing message from steering wheel electronics p1699
    18058 power train databus: missing message from instrument cluster p1650
    18044 power train databus: missing message from airbag controller p1636
    18048 internal contr. Module (eeprom) error: 1640 -static- short circuit to another valve
    18010 power supply terminal 30: voltage too low: p1602 -static- no fault type identified
    18036 power train data bus: missing message from steering angle sensor :p1628
    18057 power train databus: missing message from abs controller p1649
    18043 power train databus: missing message from a/c controller p1635
    17978 engine start blocked by immobilized p1570
    ABS BRAKES
    18031 power train databus: no communication: p1623 -static- no indication on display
    AUTO HVAC
    01172 temperature sensor: drivers heated seat (g59) -static- open/ short circuit to positive
    01171 temperature sensor: passenger heated seat (g60) -static- open/ short circuit to positive
    01206 signal for duration of ignition: OFF -static- implausible signal
    01312 power train databus -static- interrogate memory fault
    CENT. ELECT
    01312 power train databus -static- interrogate fault memory
    AIRBAGS
    00474 control module for immobilized
    STEERING WHEEL
    01304 radio -static- no communication
    INSTRUMENTS
    01314 engine control module -static- no communication
    01316 abs control module -static- no communication
    01312 power train databus -sporadic- defective
    IMMOBILIZER
    CENTRAL CONV.
    01134 alarm horn (h12) -sporadic- short circuit to earth
    01134 alarm horn (h12) -static- no communication
    00955 key 1- intermittent
    01562 right rear door -sporadic- does not lock
    I'm totally baffled and don't know where to begin, don't know whether this can be an easy fix or if my car is screwed. Anyone seen this before or can recommend what to check first? Thank you
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    No one?
    Veteran Member Three Rings Aok303's Avatar
    Jul 12 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    sound like you blew fuses or have the wrong relay plugged in, seeing how they are all broken pathway codes
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I checked all the fuses, and put the old fuel pump relay in. I also pulled out the vehicle speed sensor and cleaned all the gunk off it. And now she's runnin good again, but for how long haha
