Page 5 of 6 FirstFirst ... 3456 LastLast
Results 161 to 200 of 231
  1. #161
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    White/Yellow/Halogen/Strobe/Flash plug and play fogs:
    http://deautokey.com/product/dual-co...low-at-anytime
    We now have 2 models:
    option 1: White/Yellow/Halogen/Strobe/flash
    option 2: White/Yellow/Halogen WITHOUT strobe & flash
    -Plug and play
    -Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design)
    -Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
    -BRIGHT – this is not just a novelty bulb
    -COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
    -HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
    -SAFE – more light on the sides and down the road when dark or in bad weather conditions
    -The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
    https://www.instagram.com/p/Bpjxc_ajyaS/
    3 colors:
    -Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
    -Clean White 5500k that matches our LED & HID Headlights
    -Halogen 4300k that matches OEM
    Video cycling quickly through colors AND different strobe/flash features:
    INFO:
    -THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
    -These produce MORE LUMENS than many standalone single color white fog LEDs on the market
    -Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
    *Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
    UPDATED FAQ
    Is there a lifetime warranty?
    YES! As always this comes with a True Lifetime Warranty!
    Will your fogs keep changing colors if you use them as cornering lights?
    The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
    How does this work with the coming home feature?
    This works just like OEM. It will always be the default color of white.
    What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
    The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
    Can these turn 360 degrees?
    Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
    Are these as bright as your single color de360 fogs?
    While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
    Can you bypass the strobe feature?
    Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
    Some more fun shots - in the rain:
    White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
    And switch back to clean white:
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
  2. #162
    Feb 13 2015
    US
    Are you ready for Halloween, Fall and the winter?
    Get ready with Orange footwells
    Perfect Fall weather to install LEDs for the darker winter nights
    www.deAutoLED.com
    deAutoLED.com
  3. #163
    Feb 13 2015
    US
    Thank you for your service!
    deAutoLED.com
  4. #164
    Feb 13 2015
    US
    NEW YEAR NEW CAR UPDATES
    LEDs are going to be used everyday for the life if your car - these are tested to work and look good. DO not miss out:
    www.deAutoLED.com
    deAutoLED.com
  5. #165
    Feb 13 2015
    US
    See what you have been missing!*
    24/7 customer service
    quick shipping
    LEDs that simply work with your car and are bright!
    ​​​​​​​www.deAutoLED.com
    deAutoLED.com
  6. #166
    Feb 13 2015
    US
    See what you have been missing: Quicker LED light-up time - faster reaction time. BRIGHT dark amber that can be seen in direct sun light.
    -NO ERRORS
    -NO HYPERFLASHING
    -PLUG AND PLAY
    Due to variations it is best to look up what bulb you have either by:
    -Looking in your owner’s manual
    -You can find this info on a stamp or sticker inside your car's engine bay
    -Looking at the model on the bulb itself
    -Bulb guide:
    Bulb/LED Guide & Help | deAutoKey
    Check them out!
    PWY24W:
    New Amber or White PWY24W Front Turn Siganls Error Free Bright Fits: Most Audi Models | deAutoKey
    H16/PSY24W
    Front Turn Signals H16 PSY24W Error Free fits: Most Audi Models | deAutoKey
    PH24WY
    New Front Turn Signals PHY24W Error Free fits: Most Audi Models | deAutoKey
    bau15s:
    NEW Rear Turn Signal OSRAM 3 Tower LED Bulb Fits: Volkswagen 08 Touareg | deAutoKey
    deAutoLED.com
  7. #167
    Feb 13 2015
    US
    LEDs are a great way to upgrade your car! Your stimulus check can upgrade your Audi to ALL LEDs twice!
    Email Us for bigger discounts when upgrading your entire car with LEDs: [email protected] - we have helped many get the perfect setup with a discount!
    ​​​​​​​Thank You
    deAutoLED.com
  8. #168
    Feb 13 2015
    US
    Shipping Daily!
    www.deAutoLED.com
    deAutoLED.com
  9. #169
    Feb 13 2015
    US
    check for sales at
    www.deAutoLED.com
    ->top of banner has all updated sales!
    deAutoLED.com
  10. #170
    Feb 13 2015
    US
    Thanks for the support and seeing the difference!
    Our LEDs simply work in your Audi - we are here 24/7 to help: [email protected] & ship order daily :)
    www.deAutoLED.com
    deAutoLED.com
  11. #171
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    Do you guys sell any kind of bulb check eliminators separately, or only on certain cars with certain bulbs under certain cases? Asking for a friend with an RS7. Custom LED DRL's and turn signals, but his dash is a christmas tree.
  12. #172
    Feb 13 2015
    US
    a1dan_87 - we only sell LED bulbs that are error free - no resistors attached. If you email [email protected] with info they can help:
    -year/make/model
    -Bulb location (DRL/BRAKE/TURN ETC)
    -Color of bulb (amber/red/white)
    -Bulb type (1156, bau15s etc)
    If you send that info they can help you better.
    Thanks
    deAutoLED.com
  13. #173
    Feb 13 2015
    US
    Happy 4th of July - codes on our website banner:
    www.deAutoLED.com
    deAutoLED.com
  14. #174
    Feb 13 2015
    US
    www.deAutoLED.com
    deAutoLED.com
  15. #175
    Feb 13 2015
    US
    Join our facebook group for future discounts & deals exclusive to our FB Group members:
    https://www.facebook.com/groups/deAutoLED/
    deAutoLED.com
  16. #176
    Feb 13 2015
    US
    Check out fall sale going on now:
    www.deAutoLED.com
    deAutoLED.com
  17. #177
    Feb 13 2015
    US
    Lightbulb
    Check out sales at deAutoLED BANNER ON OUR WEBSITE:
    www.deAutoLED.com
    New sales are active until end of year (all will be listed on our website's banner) DO NOT MISS OUT!
    deAutoLED.com
  18. #178
    Feb 13 2015
    US
    LEDs that simply work - true Lifetime WARRANTY - FREE SHIPPING:
    www.deAutoLED.com
    deAutoLED.com
  19. #179
    Feb 13 2015
    US
    deAutoLED.com
  20. #180
    Jan 21 2020
    Michigan
    Quote Originally Posted by deAutoLED.com View Post
    Bright Fogs.
    [URL unfurl="true"]https://deautokey.com/fog-leds[/URL]
    Do you have hyper yellow LED fogs for C6 A6? (Not white & yellow) The ones I have tried (with resistors) didn’t work.
  21. #181
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Quote Originally Posted by pploeser View Post
    Curious as well
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
  22. #182
    Feb 13 2015
    US
    Quote Originally Posted by DC Dawg View Post
    Curious as well
    Thanks for the interest - yes just yellow work great and are very bright:
    https://deautokey.com/product/just-y...ma-fog-led-kit
    and ALL Fog Models:
    deAutoLED.com
  23. #183
    Jan 21 2020
    Michigan
    and ALL Fog Models:
    Thanks, just ordered fogs and turn signals. We’ll see how they turn out.
  24. #184
    Jan 24 2010
    Brno, Czech Republic
    deAutoLED - do your LEDs have solved out the bulb check strobing issue? Do they have some kind of flash terminator installed?
  25. #185
    Feb 13 2015
    US
    Thanks for the support. We appreciate it!
    Quote Originally Posted by -=zipp=- View Post
    They have NO outside resistors meaning you won't see a switch or resistor or anything you have to tap into your wires or to get hot.
    Everything is built in and eliminates errors.
    Thanks for the question.
    deAutoLED.com
  26. #186
    Jan 24 2010
    deAutoLED - Thank you, but you didn't really answer my question. Errors on the dash are one thing, this is where I expect your LEDs to be error free, but what about the strobing issue? A6 C6 has a non-disabledable mechanism to check outside bulbs by sending short periodic impulses to check if they are not defective (side markers, fogs, reversing lights, license plate lights). Indecent bulb doesn't light up on this short impulse, but LEDs do, causing using LEDs on our cars a nightmare. (video showing the issue below)
    I'd like to know if your LEDs have some mechanism to eliminate this, thank you.
  27. #187
    Feb 13 2015
    US
    Thank you - at this time we do not have any testing/specific resistors installed to eliminate this but we have not heard of the issue with our LEDs.
    We feel the only way to confirm is by trying our LEDs.
    Thank You
    deAutoLED.com
  28. #188
    Feb 13 2015
    US
    LISTING:
    https://deautokey.com/product/dual-c...low-at-anytime
    Dual fog switchbacks - demo video:
    deAutoLED.com
  29. #189
    Feb 13 2015
    US
    Lightbulb
    See the difference.
    www.deAutoLED.com
    We see feedback like this almost daily. We take pride in offering lighting our customers will enjoy in their car daily:
    deAutoLED.com
  30. #190
    Feb 13 2015
    US
    Lightbulb
    Listing:
    https://deautokey.com/product/univer...all-car-models
    Perfect to light up a dark trunk due to the housing being in a bad spot in your car
    We thought of everything with our plug and play trunk strip.
    -OEM adapters including making this a direct plug and play adapter into your OEM housing (Easy install)
    -48 Very BRIGHT LED Diodes*
    -Clean White or red color option available
    -Flexible & bendable with hard resin coating so it can still take a beating in your trunk
    -Can place anywhere (top, bottom or side of trunk)
    -Long wire, that is an all stealthy black which allows for an easier clean install, this wire is long enough to place anywhere in your trunk
    Customer feedback:
    "No more dark trunk. I can see everything in my trunk now"
    "Love this. It lights up the ground when I open my trunk that someone actually stopped and asked me about the light after I opened my trunk"
    "I tried other strips and so far this is the brightest and easiest install as there was no adapters to solder or tap into wires. Their plug and play adapter makes the difference"
    "Clean light that is bright and exactly what I wanted"
    deAutoLED.com
  31. #191
    Feb 13 2015
    US
    Customer LED FOG Video:
    deAutoLED.com
  32. #192
    Jan 21 2020
    Michigan
    Finally had time to install the fogs and turn signals.
    The fogs turn on and look cool but give me a persistent error. Not a single LED fog “guaranteed” to be error free has been successful on my C6. Back to the Hella halogens for now I guess…
    Signal bulbs were the wrong type so I can’t comment on those yet.
  33. #193
    Feb 13 2015
    US
    Hi, please email [email protected] - they have plug and play decoders that plug right into the LED and OEM adapter and do not get hot - that should remove any errors.
    For turns: Not sure why they were wrong but email and they can help get that fixed.
    Thank You
    deAutoLED.com
  34. #194
    Feb 13 2015
    US
    Shipping daily - LEDs made for your Audi!
    -Buy with confidence
    -no more guessing if your LEDs will work
    -Bright and look OEM
    -True Lifetime Warranty (many companies offer 1 or 2 year warranties leaving you buying LEDs - never worry about buying another LED when you purchase ours)
    www.deAutoLED.com
    Check out our Fog LED line-up: White, just yellow or dual white/yellow fogs:
    These are brighter than most on the market.
    "I have the dual white/yellow w/flash option.
    Very happy for three years now a great value, in the high contrast use seeing obstacles "softroading"...plus snow, plus the white extra light into ditches in deer season.."
    deAutoLED.com
  35. #195
    Feb 13 2015
    US
    https://www.deautoled.com/ - sale on website banner
    -Error Free
    -Bright
    -Simply work in your Audi*
    -24/7 Support - [email protected]
    ​​​​​​​We can help you find the right LEDs for your Audi.
    deAutoLED.com
  36. #196
    Feb 13 2015
    US
    Labor Day Sale ON NOW!! Check out website's banner for the deal of the year:
    www.deAutoLED.com
    -Error Free
    -Bright diodes
    -Thin PCB board for clean light output
    -True Lifetime Warranty (Leading warranty in the industry). This is truly the last LED you will have to buy for your car.
    -FREE Shipping within the US
    -24/7 support. Our team will reply with any questions almost instantly:
    https://deautokey.com/contact
    Compared to many top competitors are pricing are less and our diodes are brighter.
    Stop guessing what will work and do it right the first time. Customer feedback consistently shows where other LEDs caused errors & were dim ours were error free & bright.
    We are here to make sure you get the product you want that works in your VW/Audi (and many more car models).
    Bright fog LEDs where you want light - in white, yellow or dual fogs white/yellow:
    deAutoLED.com
  37. #197
    Feb 13 2015
    US
    Checkout www.deAutoLED.com ​for extended sale - limited time - hurry!
    deAutoLED.com
  38. #198
    Feb 13 2015
    US
    Choose your style of fog:
    deAutoLED.com
  39. #199
    Jul 27 2018
    2010 Audi A6 Avant 3.0T
    Coquitlam, BC
    I'm guessing you got the Dual Color LED Fog [1 bulb 2 colors] option with resistor correct ? In the H11 format for the C6.
    Do you have the round or the rectangle fog lights ? i'm guessing the housing doesn't matter since both are H11
    Did you swap any other LEDs ?
    I'm thinking of doing the interior as well; does anybody know if any coding issues with moving to LEDs on the interior ?
    Pending answers i'll be ordering this soon :P
  40. #200
    Jul 27 2018
    Coquitlam, BC
    Ahh i got a message that the fog lights can't be shipped to canada. Not great.
    Perhaps a note on the website to indicate when this changes.
