Results 1 to 7 of 7
    Veteran Member Four Rings Tanzimur's Avatar
    Feb 21 2013
    97 Brilliant Black A4 B5 1.8T
    Warren, MI
    01 Awm Coil Pack Harness And Coils To Aeb?
    So my question is, will the stock coil pack harness and coil packs from a 2001 Awm work just as a 2.0t coil pack conversion in the mean time while i wait for the red top 2.0t coils to come in?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    yes, and yes. as long as you wire the harness in correctly, it will work.
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Feb 21 2013
    Warren, MI
    for sure appreciate the reply! now do i run the same gap with theese coils? or run bigger ones?
    Dec 13 2010
    FL
    should be stock gap. the 2.0 coils allow for a larger gap
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Grape is right, but something he didnt mention is you either need to swap valve covers or get hold downs for the coils if using an AEB valvecover
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Dec 13 2010
    FL
    Quote Originally Posted by redline380 View Post
    not sure ifthe awm coils need hold downs in an aeb cover, but the 2.0 coils can be ran on aeb without them.
    Feb 21 2013
    Warren, MI
    ye i already have an awm cover, the aeb cover the awm coils get cauhght up in the hole! thanks!
