Results 1 to 8 of 8
    May 11 2013
    Nnj
    main bolt & rod cap bolt socket size?
    im in the process of tearing down my short and just realized that i dont have any interal torx sockets. what sizes do i need for the main and rod caps?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    10 or 12 from what i remember
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    May 11 2013
    Nnj
    Okay great thank you for the fast response
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    they're called external torx.
    its an e12 for the rods and an e14 for the mains
    I got mine from Sears, but if you're desperate I noticed some at Home Depot.
    May 11 2013
    Nnj
    Quote Originally Posted by y3ti View Post
    you are correct. thanks for the info.
    Veteran Member Four Rings RocksForsSale's Avatar
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    thanks!
    Jan 11 2017
    MI
    FWIW, it's often cheaper in the log run to buy a small set of Torx sockets/drivers if you can and then you'll have them for other fasteners that require a different size socket/driver. When sold individually the prices are often substantially more and when you need a different size you need to order them or run to the auto parts store to buy them which can be a PITA when you need to do a quick repair.
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    Get a whole set at harbor freight for cheap yo!
