Can someone elaborate?
I am familiar with AEB and ATW, but need to remotely help my brother with his 2000 A4 Quattro 1.T 5 spd with APU engine and 4B0 906 018 AA ECU. Building autocross car.
What is similar to AEB (20mm rods, writst pin, high flow cylinder head, high flow intake, no valve cover vent, using the old style square coils and ICM, etc) ?
What is similar to ATW (electronic throttle drive by wire (not like AEB drive by cable), modern ECU (flashable)?
Other differences to AEB, ATW?
Other commonalities with AEB, ATW?
Displacement.................... 1.8
Output kW/rpm................. 110/5700
Torque Nm/rpm................ 210/1750...4600
Bore................................ 81.0
Stroke............................. 86.4
Compression ratio............ 9.5:1
RON................................ 95 unleaded
Injection......................... Motronic ME7.5
Ignition........................... Motronic ME7.5
Exhaust emissions............ MVEG 2
EPC system..................... yes
Knock control.................. yes
Self-diagnosis.................. yes
Lambda control................ yes
Catalyst.......................... yes
Exhaust gas recirculation.. no
Secondary air system....... no
Charged.......................... yes
Variable path intake manifold no
Variable valve timing........ no
Turbo.............................. K03
