    Aug 07 2011
    SL 55 AMG, GLS 550 C5 Allroad 2.7T 6MT
    Sunny Fl
    Tire width question.
    Just picked up an 05 225 Quattro. I found a set of 18X10 et 25 wheels that I like. My question is what size tire would give the wheel enough protection and not rub. I'm not knocking it but I'm just not a fan of the "stretched" look.
    I've read that 255 40 18's should work... Anyone have pics of wheel/tire combos near that size?
    Established Member Two Rings SimbadCA's Avatar
    May 11 2016
    Audi TT (MK1, 8N) Quattro
    Camarillo CA
    Quote Originally Posted by Das22 View Post
    Did you ever get a response? Has anyone had success with wider tires/wheels in 18 inch?
    I was hoping to get 245s or 255s.
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    wider wheels can be done for sure. You have a ton of room to work with. I'll be putting on a set of 18x9 wheels tomorrow. I'll try and post some pictures for you.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    May 11 2016
    Camarillo CA
    I often wonder if the TT Mk1 drivers are still active.
    Mine is not a daily driver, but occasional street and track use. This week I managed to get the car of the jack stands after replacing brakes, and installing some coilovers. Prior to this refurbishment, I managed to get the car over to ButtonWillow raceway for a fun day, and the car did great without any other mechanical issues. I want wider tires, but I don't want any issues on tight turns.
    May 11 2016
    Camarillo CA
    Any idea why the Mk2 started using a larger hub dimension; 5x100 vs 5x112?
    Sent from my iPhone using Tapatalk Pro
