Results 1 to 13 of 13
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    Rear diff drain plug leaking
    I've developed a slow leak from my rear diff drain plug over the years. I re torqued it a few times but it continues to drip. I was planning on removing it then cleaning everything, then sealing it with lots of RTV. There is no need to replace the plug itself im assuming?
    Dec 10 2013
    Borden, Ontario, Canada
    They're like $5 from the dealer. I don't see why you wouldn't replace it for that low price
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Of throw some teflon tape on the threads.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    ^^This and check the threads in the case.
    You may have threaded the plug to deep.
    It happens all the time on rear ends.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    I think you are supposed to replace it if you remove it. That's what I have read online.
    May 16 2008
    South Texas
    You can also use a crush washer under the plug.
    Jul 04 2012
    Woodbridge, VA
    Teflon, crush washer, new plug, and lots of rtv. That'll fix it.... Just kidding. I'd personally use replace it and use a crush washer.
    Jan 01 2011
    Nor cal
    Thank you all, I didn't even know there was an option of using a crush washer on there. I teflon taped the new plug, added a washer and used RTV and its sealed up fine! Prost
    Jan 01 2011
    Nor cal
    So the diff leak ended up not being the drain plug. Im pretty sure it is coming from the larger outer face of the diff housing, not the axle seal. Is there a gasket for this portion, could not find one?
    Dec 10 2013
    Quote Originally Posted by killerkali View Post
    Connecting the prop-shaft to the diff snout? There is a seal in there, but to do it you gotta remove the diff from the car
    IG: 24_et
    Sold:
    RIP:
    Aug 06 2008
    Canadia
    If its the diff pinion seal i would live with it, that seal is generally not easily re&re'd on a ZF diff
    the B5 S4 is like the mafia... there is only one way out!
    Jan 01 2011
    Nor cal
    Seems to be coming from where the larger outer face mates to the case, on the bottom of course .
    Feb 27 2011
    Winnipeg
    the diff side cover is probably sealed with an anerobic sealer like loctite 515 or similar. You sure its not an axle seal leaking and the fluid is blowing around under the car?
