I wanted to create a thread to put all of my dyno results in one place. Also, for those curious as to what each stage is doing in real world numbers. In addition, to make sure I was really making the power that I was paying for.
All dyno runs were performed on the same mustang dyno by the same tech. Ambient conditions were very similar. ~4000-5000 DA
I'm glad to see a decent increase with the RocEuro intake (may actually be E85blend that caused the increase). Also, the AMS cooler was working beautifully. We did 6 back to back runs today (7/2) with only a couple minutes between runs and the car pulled consistent numbers throughout each. All within 1-3hp of each other. The tech was very impressed on how smooth and consistent the power curve is and surprisingly how stable the AFR was with the E85 blend. I was also data logging throughout to make sure timing was good. I will be going through that data later.
Mustang Dynamometer, uncorrected, ~4000+DA
Stock -91 octane | APR Stage 1 -91 map | APR Stage 1 -91 map +E85blend (E25) | APR Stage 1 -93 map +E85blend (E25) | APR Stage 2 -93 map +E85blend (E36) | APR Stage 2 -100 map +E85blend (E36) | |
AWHP actual | 369.3 | 395.5 | 416.9 | 433.2 | 437.5 | 453.7 |
AWTQ actual | 352.3 | 469.2 | 497.5 | 523.9 | 559.7 | 583.9 |
APR Stage 1
- 91 map
- AWE Touring Exhaust
- 21" TSW Bathurst ~5lbs/ea. weight savings
- 91 map
- 91/E85 blend (~E25)
- RocEuro Intake
- AMS Cooler
- 91 map
vs.
APR Stage 1- 91 map
- RocEuro Intake
- AMS Cooler
APR Stage 1-91 map | APR Stage 1-91 map + RocEuro | |
AWHP actual | 395.5 | 416.9 |
AWTQ actual | 469.2 | 497.5 |
APR Stage 1
- 91 map
- RocEuro Intake
- AMS Cooler
- 93 map
- RocEuro Intake
- AMS Cooler
- 91 map
- RocEuro Intake
- AMS Cooler
vs.
APR Stage 1- 93 map
- RocEuro Intake
- AMS Cooler
APR Stage 1-91 map | APR Stage 1-93 map | |
AWHP actual | 416.9 | 433.2 |
AWTQ actual | 497.5 | 523.9 |
