    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    OBD2 scanner and timing advance
    Ok so please excuse me and try to explain like I am a 5 year old hahaha. I am a total noob at tuning cars, data logging and knowing what to look for.
    So I just got an OBD2 scanner and torque pro app. Seems really cool and fun. What I am trying to do besides running 0-60, 1/8 mile times etc. is also see if the piggyback I am running is negatively effecting my car. So after a little research it seems I want to log timing advance and revs right?
    So If i log a WOT run with Rpms and timing advance will that log show me what I am looking for and could you guys look at a log and help me decipher it?
    Thanks for any help!
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    When I run the APR logging tool these are the parameters I usually log:
    • throttle position
    • engine speed (RPM)
    • boost pressure
    • lambda/AFR
    • individual cylinder timing retard
    • timing angle
    • cylinder misfires
    You can probably monitor temperatures too. I'm pretty new to this too so I'm sure more experienced data loggers can chime in. HTH
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Avned View Post
    • throttle position
    • boost pressure
    • lambda/AFR
    • timing angle
    • cylinder misfires
    So I just logged a bunch of stuff, its quite a cool tool for 30 bucks and a $5 android app. Am I right that I don't want to see negative #s in the timing advance under heavy load? Most of the time its a positive # but occasionally it shows a -14.5 at around 4,500 rpm.
    Nov 28 2015
    Montreal, QC
    have you been able to get accurate 0-100kmh times ?
    S4 B8.5 no track, just enjoying spirited driving.
    Sep 19 2014
    Newcastle
    Not even close for me. I can't get it to read boost properly
    Sent from my XT1580 using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
