Results 1 to 4 of 4
    Established Member Two Rings Goneau's Avatar
    Feb 15 2015
    Connecticut
    HELP? P0010 and not starting
    Hey guys,
    So a few weeks ago I was driving to go get gas, went about a 1/4 mile and at a stop sign the motor just stopped running. No sputter, no shake, nothing. Just stopped
    Scanned the codes and P0010 came up as Cam chain tensioner short circuit
    Well, I tested the solenoid and it came up as 4 ohms, so I replaced it with a junkyard solenoid that tested as 8 ohms from prong to prong. Well still nothing. It'll turn over, and I can hear the turbo spinning if I try and start it for a few seconds.
    I have not done a compression test yet, and I'm really lost. Any suggestions?
    Feb 15 2015
    Connecticut
    Should add its a 2001 A4 1.8T Quattro manual AWM
    Sent from my XT1254 using Tapatalk
    Feb 15 2015
    Connecticut
    Bump
    May 05 2016
    alaska
    Have you pulled the valve cover to check the cam chain and tensioner? That's where I would start
    Sent from my SAMSUNG-SM-G870A using Tapatalk
