Results 1 to 13 of 13
    Nov 10 2013
    annapolis, md
    75k DSG Fluid Change
    I'm about to schedule a visit to get my 75k DSG Fluid/Filter Changed on my B8 and was wondering if I need to buy any new stretch bolts. Specifically I have a alu kreuz drivetrain stabilizer and it uses stretch bolts. Obviously when changing the DSG fluid you need to take the alu Kreuz off. So should I purchase new stretch bolts? Basically my question is, other then the filters and the DSG fluids do I need anything else for my 75k DSG fluid change? Lastly, the shop where I plan to take it charges $600 for a DSG Fluid change filter, etc. Do you think that's a reasonable/fair price? Happy 4th and thank for the advice in advance.
    2011 Deep Sea Blue S4
    7-speed DSG / B&O / MMI with Nav / Advanced Key / Carbon Atlas Inlays / Black Leather /19" Peelers/Push Button Start/Sport-Diff/Comfort Mode;)
    Modifications: Stage 2 GIAC w/Emmanuel Design Pulley, TCU DSG GIAC Tune, EuroCode Alu Kreuz, Roc Euro Intake, 034 Trans mount, Apikol mount, H&R front & rear sways
    Nov 28 2015
    Montreal, QC
    i think the dealer charges like 400$...thats an excessive price...
    S4 B8.5 no track, just enjoying spirited driving.
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    Quote Originally Posted by waxxonMTL View Post
    im pretty sure the dealer will charge about $750 or so, so $600 seems fair.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Mar 21 2015
    ^ I agree
    Nov 28 2015
    Montreal, QC
    oh lord this is expensive :O i paid 60$ in labour and supplied all the parts, guess i got a sweet deal lol!
    Nov 10 2013
    annapolis, md
    Do I need to replace any stretch bolts when I do the DSG change or am I good? According to the shop there is no bolts to replace, they just do the DSG fluid filter change and that's it.
    Mar 21 2015
    I don't recall seeing anyone removing the the brace and it's not listed here
    May 06 2004
    W124s
    PA
    Not a problem with the stock brace, but seems the Alukruez doesn't factor dsg fluid change.... Definitely in the way of the drain plug
    Keep right pass left, it's the law!!
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    Quote Originally Posted by quickglx View Post
    Huh, didn't know that. And me with an Alukreuz and 75K coming up. Awesome.
    Nov 10 2013
    annapolis, md
    So when I remove the Alu kruez because its in the way of the drain plug should I get new stretch bolts for my Alu Kruez or just reuse the bolts? I remember reading on here somewhere about needing to replace a total 15 bolts when you do the DSG fluid change. Can anyone confirm one way or the other?
    Mar 21 2015
    ^ Rule of thumb is to replace and torque properly when using stretch bolts.
    Jun 28 2016
    US
    Quote Originally Posted by z_curtis_s4 View Post
    15 bolts? There's 15 bolts holding the AK to the subframe? ;) If you want to be safe, replace those stretch bolts. The Audi repair manual asks for it, but I've seen Audi mechanics reuse them all the time.
    Mar 21 2015
    034 x brace has 6 with the bolt kit
