Results 1 to 7 of 7
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Brake light message on LCD
    How does the computer generate the alarm? All of my tail lights work and I am still getting the message on the display.
    I can't imagine it is shorting out or anything because the lights wouldn't work. Mice may have gotten at the wiring.
    Noob question- is the cluster supposed to be lit up without the lights on? This is my first S4 and the A4 clusters do not light up until the lights are turned on.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by redline380 View Post
    flase. facelift a4 clusters do not light up until the lights are turned on, prefacelift cluster lights are always on
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    My cluster lights are always on, lights on or not. I also had a brake light warning come up, and my lights were also working. Changed the bulbs, no problems since then. Gl
    2002 Pearl/onyx S4 Avant
    Dec 13 2010
    FL
    ^i had the same issue as this guy in my volvo. changed the bulbs and brake light warning on dash hasnt lit up. could have been a bad or dirty contact on the bulb, who knows
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Ok great, I will try some new bulbs tonight to see if that works. Kinda funny that both lights work but the message is still on. I took the panels off last night but did not remove the bulbs.
    On a side note, my brake warning light is also on and I already shorted them. I'll have to see if one of the clips inside the fender liner is broken or otherwise not clipped in
    2000 S4- Working?
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Works by checking resistance. You aren't running LED bulbs are you?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by DieselElectric View Post
    No, they are regular halogen bulbs. I should mention that the license plate lights did not work because of corrosion on the terminals. I need to get new lenses for them.
    2000 S4- Working?
