Results 1 to 4 of 4
Thread: Fan testing
    Jul 02 2015
    Bermuda Dunes
    Fan testing
    Does anyone have a fan wiring diagram or a link to write up to test the fans and or fan control module? My drivers side fan is not working. It 100+ degrees here so I need to fix it so my A/C will blow cold when I'm not moving. Appreciate any heads up, I'm trying to avoid having to spend time in the heat figuring it out on my own.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    Active Member Two Rings kevtotha's Avatar
    Aug 15 2014
    huntsville, AL.
    Just hard wire the fan to the battery to see if its actually the fan that's bad. Its the big two wire plug on the FCM. It's a fairly quick and very easy way to test the fan. Be sure to test it a couple times tho. My fan would spin up the first time I hooked it up to the battery but the second time it wouldn't do anything. Hope this helps.
    Jul 02 2015
    Bermuda Dunes
    Exactly what I was looking for thank you, not sure how I missed this thread when searching.
