Results 1 to 9 of 9
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Turbocharger coolant line leak?
    Ever since my Audi SA mentioned the turbo lines slightly leaking, I've been monitoring it. My dealer was going to replace it at the time, but the big guys upstairs say that the slight leak is normal. Today, when I got my car back from the APR shop, I looked again at the turbos and noticed the liquid to be fresh as opposed to hardened as before. Looks like it is on both turbos. According to the parts schematic it seems to be the 'turbo coolant lines or oil lines'. Has anyone had this issue before? Should I have Audi revisit this issue?
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Jan 27 2016
    '14 QX80, '12 FJ Cruiser (Heavily modded)
    Denver
    I think this is TSB 2036167/2 . Technical Service Bulletin // 19 Coolant pipe seepage on turbocharger
    Technical Background
    There may be slow coolant loss from the connections of the coolant feed pipe and coolant return pipe. High temperatures cause the coolant to become encrusted on the connection flange of the turbocharger.
    Production Solution
    Modified coolant feed pipes, coolant return pipes, and o-rings. Service
    1.Drain the cooling system.
    2.Replace the coolant feed pipes and coolant return pipes for both cylinder banks. 3.Replace the oil feed pipe o-rings.
    4.Tighten the coolant line and oil line hold-down bolts to 9nm.
    5.Fill and bleed the cooling system.
    Claim Type:
    110
    If vehicle is outside any warranty, this Technical Service Bulletin is informational only.
    Current:
    '13 S7 (Innovation, B&O, LED's, AWE Exhaust, RS-Grille) -- '12 FJ Cruiser (Heavily modded) -- '14 QX80
    Gone but not forgotten:
    2014 Porsche Carrera S -- 2014 Toyota 4Runner -- 2002 Acura TL-S (My first 'luxury' car)
    Apr 20 2016
    Las Vegas
    Thanks for the information!
    '22 RSQ8
    Junior Member One Ring
    Jun 05 2021
    2018 Audi Q5
    Springfield, Massachusetts
    Do anyone know the average price of getting the turbocharger coolant return line replaced on a 2015 S7. I think audi is out their mind for what they quoting me. I know there's a leak and was told it's the coolant return line to the turbocharger. Thanks in advance
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Reece6776 View Post
    Maybe ask them to do it with the screen recall...should be less labor then.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 03 2009
    Iowa
    To answer your question, the coolant return line o-rings would be easy. I would bet you could do those yourself in 15 minutes. Those are the fittings closest to the exhaust manifolds on both sides. They head towards the back of the engine.
    The oil and coolant feed lines both appear to require the removal of the PCV. This would be a lot of labor. For the record, the oil feed lines are the ones in the middle.
    If your quote is super high, I would imagine they quoted doing all of the o-rings. And in that case, as gk1 says, oil screen time.
    Jun 05 2021
    2018 Audi Q5
    qcrazy thanks an I was actually thinking about that yesterday what gk1 mentioned which makes alot of sense to me. I'm waiting on the go for the repair to be available for the recall an will definitely have that added into it as well.
    Sep 19 2012
    Q5,Mercedes C55,Mercedes 500SL
    Bainbridge Island , Washington
    Question: My S6 in the shop for the screen recall. Did you have the O rings replaced at the same time and what was the cost? They are quoting me $800 to replace the o rings while it's in the shop. Crazy!
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by bobs View Post
    It should be included as part of the recall, but who knows for sure if they do it or take shortcuts or modified the original TSB for a cheaper recall.
    For me they actually broke my o-rings during the screen change and I had to change them myself again.
    They are listed right in the TSB along with several others.
    N 91056801- Upper oil supply o-rings 12x2 black 2
    N 90303801 - Lower oil supply o-rings 9x1.5 black 2
    WHT006901A - Oil return o-rings 14.5x2 2
    N 90465003 - Water tube o-rings 23x2.6 3
    WHT006335A - Turbo coolant pipe o-rings lines (blue 2.0mm)
    Note: Installed seals are based on which pipes are installed (see TSB 2036167). 4
    WHT006537 - Turbo coolant pipe o-rings lines (black 2.8mm)
    WHT001011A - Coolant supply pipe lower o-rings yellow 12.2x1.65 2
    Perf, Leather, Exec
    2015 S6 Quartz Gray
