Results 1 to 2 of 2
    Established Member Two Rings Hazziar's Avatar
    Oct 03 2010
    01 A4 Black
    Northeast
    Drive-Shaft Center Support Bearing Replacement — B5 A4/S4
    I replaced the drive-shaft center support bearing aka carrier bearing on my B5 A4 and this is how I went about it.
    TIME/DIFFICULTY
    5-8hrs factoring in Murphy’s Law
    Medium difficulty range
    Must make your own special tool
    PARTS
    ₪ Drive-Shaft Center Support Bearing***
    ₪ CV Gasket 183521141A x2
    ₪ CV Grease
    TOOLS
    [Key requirements]
    - 10mm Socket
    - 13mm Socket
    - 28mm or 1-1/8” Socket
    - 6mm Allen Socket
    - T45 Torx Socket
    - 3/8” Extensions
    - 16mm or 5/8” Combination Wrench [to be modified]
    - Large Flat-Head Screwdriver
    - Angle or Bench Grinder
    - Jack and Stands
    [Basic necessities]
    - a solid metric tool set
    - Allen and Torx Socket sets
    - 3/8” Torque Wrench
    - Small Flat-Head Screwdriver
    - Ball-Peen Hammer
    - Vice Grip
    - Tape Measure
    - Razor Blade
    - LocTite Blue or Red
    - Paint Pen or Sharpie
    [Misc.]
    - Penetrating Spray
    - Plastic Bags
    - Shop Rags
    ***I bought mine from Colorado Drive Shaft. Call or email David. Very knowledgeable and outstanding person to do business with, his company has been rebuilding drive-shafts for 25 years with VW/Audi drive-lines being one of their specialties. Overall I was very impressed with the part and service.
    SETUP/DRIVE-SHAFT REMOVAL
    — Apply hand-brake, raise car on jack stands.
    — Remove exhaust system from down-pipes.
    — Remove drive-shaft heat shield using a 10mm socket to undo the 4 fasteners.
    — Remove drive-shaft shield from transmission using a T45 Torx socket to undo the 2 screws.
    — Remove the 6 allen bolts from both CV joints using a 6mm Allen socket. Loosen 2 bolts then release hand-brake, rotate shaft, reapply hand-brake, loosen the next 2 bolts, repeat for last 2 bolts.
    — Dislodge the CV joints from the flanges using the rounded end of a Ball-Peen Hammer. A few sharp hits on the CV body will do the trick.
    — Unbolt the carrier and remove drive-shaft. Loosen the 2 bolts with a 13mm socket, when the bolts are nearly off - brace the carrier with one hand while removing the bolts with the other. At this point lower the drive-shaft on your chest and “slip” out from under the car.
    Note: this step is better done with a second set of hands but you’ll miss out on some great theatrics.
    — Cover CV joints with plastic bags as soon as the drive-shaft is out.
    — Spray penetrant around the yoke bolt and let sit. Stand drive-shaft upright when doing this as to not let any of the liquid seep around the u-joint.
    __________________________________________________
    The next three procedures don’t exist in any service manual because the carrier is “Non-Serviceable” as deemed by Audi. You are literally entering the Matrix of Audi repairs. With that said; this is my way, but it’s only one way, and though it worked for me, it might not work for everyone. The following should only be considered for reference and not rule.
    SPECIAL TOOL/BOLT REMOVAL
    — A 16mm or 5/8” combination wrench and an angle or bench grinder are needed. The tool will be made in 3 stages.
    Stage 1
    — Grind the back of the wrench head as shown. If using a 5/8” wrench; trim the opening until it fits onto the 16mm bolt. Only remove enough material until wrench fits and has room to make an 1/8” turn to partially break the bolt free. Attach a Vice Grip on the yoke to hold drive-shaft in place.
    Stage 2
    — After the bolt is partially broke free continue to remove more material. Start to grind a curve into the neck. Then turn bolt further.
    Stage 3 – Final Form
    — Now continue to remove more material as needed at the neck and head until bolt is able to be turned enough to allow the wrench to be moved back to its previous position to make another turn.
    SHAFT SEPARATION
    — Make alignment marks on the yoke and shaft as shown. It’s critical to make these marks as accurate as possible for rejoining later on. The drive-shaft can become out-of-balance even if off by only one spline.
    — Unthread bolt far enough out to wedge a large screwdriver at a slight angle between the yoke and bolt as shown [do not put any pressure on the u-joint itself], force pressure against the bolt and firmly hit screwdriver with hammer. As shaft begins to separate; unthread bolt further and keep repeating previous steps until fully split.
    CARRIER INSTALLATION
    — Remove old carrier. Cut carrier frame off with a razor blade, place large flat-head screwdriver on carrier lip as shown, hit firmly with hammer until bearing comes off. Use caution as to not bend the shaft ridge.
    Note: using a bearing splitter and press is ideal for this step and the next.
    — Install new carrier. The carrier goes on with the “Cupped” side facing up. A 28mm or 1-1/8” socket fits perfectly on the bearing race to act as a strike or press point. Fully seat bearing with a few light hits by hammer or press bearing in place.
    — Rejoin drive-shaft. First apply LocTite blue or red on bolt threads, align both ends of the drive-shaft with the marks made previously and slip splined ends together. Now thread then tighten bolt as much as possible.
    Tip: holding bolt in place with a small flat-head screwdriver or pick will make getting the threads started much easier.
    — Now take time to look over the drive-shaft and admire your work.
    DRIVE-SHAFT REINSTALLATION
    — Clean and grease both CV joints and install a new gasket on each flange.
    — Install drive-shaft in the reverse order of removal.
    — Torque CV joint bolts in a star pattern to 41ft-lb [55nm].
    — Perform alignment [see “Alignment” in the next section].
    — Torque carrier mounting bolts to 18ft-lb [25nm].
    — Give the shaft a few spins while inspecting your work.
    ALIGNMENT
    — Turn shaft until the yoke off the carrier is perfectly horizontal, now measure from the center of the u-joint cup to the ridge of the opposing yoke on both sides as shown. Slide carrier side-to-side as needed until the measurements become equal on both sides of the yokes. Tighten carrier mounting bolts, spin shaft, check measurements, and make adjustments as necessary until measurements are perfectly equal. At this point the drive-shaft is aligned.
    FINAL DETAILS
    — Reinstall drive-shaft heat shield
    — Reinstall exhaust
    — Lower off jack stands
    — Take a test drive
    — Yell out the window “I am Ze Übermensch!!!”
    Sep 12 2008
    South Central PA
    This is a great write up, nothing left out. Quality post.
    I am doing this soon, definitely going to keep this page up on the laptop in the garage.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
