thanks guys, i completed the intake and here is my review. I'll be making a few more minor adjustments to the air scoop/heat sheild but for now im just trying to enjoy the completed project :)
what I bought:
- Thermo- Tec 12 x 24 $22
- M-D Building Products 56020 1-Feet by 2-Feet Galvanized Steel Sheet $11 each x 2.
- K&N RF-1047 Universal Air Filter $61
total : $105
I already had a silicone turbo inlet pipe and Id recommend having this as you will need to cut it down on both ends to adjust the intake position. (ill post pictures in the future)
Pro:
- saved $170 to $190 dollars (compared to the Typhoon or Luft-Technik intake respectively) or saved $370 compared to APR's Carbonio's intake
- fun DIY project, mostly easy
- It greatly enhanced the DV+ i have. I really like the whooossh it makes when shifting now. I didnt experience this before with my drop in.
- supposed increase in HP (though not enough to notice... its never enough haha)
cons:
- has that annoying whistle/ high pitch sound when moderately accelerating, not there with slow accel and full throttle. see link ->
http://www.audizine.com/forum/showth...i-A4-2-0/page5
- wear gloves or you'll have cuts from getting creative with the heat shield ( i kept taking my gloves off, god damnit!)
- careful with the maf cord and plastic clips when removing
So im guessing it's the same sound has the Typhoon. I'd really like to meet up with someone that has an intake to compare it to. Videos don't do enough justice.
conclusion: If you're someone that likes to do things yourself and save money Id suggest you make you're own intake and post about it. Maybe you can improve upon what i've done here. ill try to post more of a step by step with cut dimensions i used for the heat shield/ air scoop. just be warned, do this at your own risk and be aware of the annoying whistle these intakes make. I have an aFe drop in for back up that i can see myself going back to eventually, unless someone knows how to get that annoy whistle away. For now im quite satisfied.
