Page 1 of 3 123 LastLast
Results 1 to 40 of 99
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    Best new Standalone ECU?
    I recently had a conversation with 034 where they told me they are discontinuing their support for their 034efi system. They also no longer provide custom tuning for our platform, only off the shelf tunes.
    A lot has changed in the standalone market since 034 EFI and this platform was first introduced. So what is the best option for someone who can't stand Me7 due to its complexity and unreliability (atleast in my case).
    I know there are not any plug and play options (maybe im wrong) but what sort of custom wiring systems would work properly on our cars?
    Jan 05 2010
    burnaby british columbia
    Quote Originally Posted by rguil View Post
    I will be running link standalone ecu. Link used to be vipec. They have can bus , so abs and gauges will still work. This will be done with full custom engine harness and flex fuel . I hope car will be ready in few month.
    Sent from my SM-N900W8 using Tapatalk
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Honestly if I were going standalone I would just throw Megasquirt in, and build a new harness.
    Simple, and effective. Plus if you are into it, you can build the thing yourself. I did one before and really enjoyed it. Although the premade ones are very well built.
    Dec 17 2014
    San Diego CA
    Quote Originally Posted by DieselElectric View Post
    So with a Megasquirt, will all the OEM sensors, vvt, and coolant temp sensors and all that fun stuff work or does it need to be changed?
    Nov 02 2014
    Winchester, VA
    Quote Originally Posted by replica_rs4 View Post
    I didn't think the B5 S4 was a can bus setup?
    Jan 05 2010
    Earlier EU versions weren't, but north American market was facelift model with can bus.
    Mar 22 2013
    AK
    The "best" stand alone is Motec.....if you have the coin
    Btw the 1200 hp Hanover Limo is ME7 .......ME 7 is superior to almost any stand alone
    Feb 05 2014
    BROOKLYN
    Quote Originally Posted by Drehmoment View Post
    Prove it. Don't just say it!
    Dec 17 2014
    San Diego CA
    I understand the capabilities of ME7, there is just so much Audi electrical crap that interferes with the my mechanically proper car on almost a weekly basis and the lack of tuners is kind of lame
    - - - Updated - - -
    Quote Originally Posted by Yuppie View Post
    Look into ProEFI and since you are in Tahoe why don't you reach out to Jared at VLM Spec and bounce ideas off of him. He has good amount of knowledge on standalone along with our factory ECU.
    Ok definetally! Thanks!
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2000 S4 Nogaro Sedan Stage 3 WMS-Current
    2001 S4 Sil Sedan ASP Stage 3-SOLD
    2002 S4 Pearl White Avant Stock-SOLD
    2000 S4 Nogaro Sedan EPL Stage III-SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III-SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s-SOLD
    2001.5 Nogaro Sedan AWE Stage III-SOLD (x2)
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast-SOLD
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    I really don't see the need for standalone on our cars due the addition of Antilag and no lift shit to our ecus and the fact that you have full control over everything you would want to adjust but you have to know how to tune me7 so I can see the appeal of a Standalone system in that regard but once you learn what maps do what the car can perform just as good if not better than with a standalone system. That's probably why 034 is no longer supporting their setup.
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Vems is solid. Super easy software and its plug and play.
    Senior Member Three Rings cinesnow's Avatar
    Jun 10 2012
    stg 3+ b5 s4 (black) b5 s4 (white) '01 allroad 6mt, 993 targa, '05.5 elise, '65 356c
    Local park bench
    AEM infinity 8 is what I'll be doing on my car this fall, Cody Gulstrand has already mapped the pinout and can make an adapter for the stock engine harness. it's plug and play less tuning, Pm me if you want to know more.
    Racing is life, everything that happens before or after is just waiting...
    Dec 14 2008
    Finland
    http://www.maxxtuning.eu/products/en...hrottle-agbazb
    World's Fastest B5 Avant biturbo Full Weight
    With Race Seats @3800lbs
    TTE950+ 100-200kmh 3,81s
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Contact srsmotorsport.com, he is my friend and he can set you up with a plug and play VEMS setup, with E-throttle,
    he will most probably beat anyone's price.
    He can also make you a brand new wiring harness or an adapter for your OEM wiring harness. I'd go with a new
    harness though due to the age of them.
    Sep 13 2014
    Land Cruiser HDJ81
    Anyone successfully run standalone with the factory cluster? I know there are certain advantages to something like a racepak, but I am a huge fan of keeping the stock gauges on a street car.
    2000 B5 S4, Laser Red
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Penpusher View Post
    Keep the stock ECU then. Run both.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jan 05 2010
    In theory standalone that has can support for 1.8t vw/Audi should work with stock gauges and abs in our cars . So far I know AEM infinity , halltec and link vipec should work. I'm getting link g4 thunder installed with custom harness. I'm sure there is others that I don't know of that would also work.
    Sep 13 2014
    Land Cruiser HDJ81
    That's the thing though...I hear that it is theoretically possible but have yet to see an example of it being done. Same goes for running the stock gauges with the stock ECU and controlling the engine via standalone.
    Looking forward to seeing your setup.
    Jan 05 2010
    There is a b6 a4 in Australia I believe , he is running a vipec that was intended for first get Audi TT. Plug in version . he had to modify a few things like a e thermostat and some other things but it works like a charm. Worst case I will recode everything to 1.8t and that should work. After all when people do swaps like 1.8 to 2.7 they have to recode to make electronic understand each other. So I will recode in reverse like swaping 2.7 for 1.8 t. Essentially tricking ecu in thinking my car is a4
    Feb 19 2011
    Earth
    Loads of guys in australia running Link/Vipec ecu's (plug and play) and have working A/C and gauges.
    2000 Achat S4
    Aug 08 2014
    New Zealand
    Hi there I have one of the old link xtream ecu really good so far
    Registered User Four Rings
    Sep 01 2013
    Sweden
    There is really no reason to use stanalone on 2.7t bc oem Me7.1 is capable of just about Everything. Find a good tuner and keep it simple.
    Dec 17 2014
    San Diego CA
    Quote Originally Posted by Mocke View Post
    I think what i find the most appealing is the ability to have a ethanol content analyser that changes the map on the fly.
    Jan 05 2010
    Me7 is pretty sweet , reason I went standalone is
    Flex fuel even thou I know there are tuners working on me7 flex fuel set up.
    My harness was in very poor shape , so I'm getting a custom harness .
    I wanted to delete all the emissions sensors with out wiring in resistors .
    Ability to run with no maf .
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    There are lots of reasons to run standalone over ME7.
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Also you can use wideband lambdas with the standalone, and 4 bar map wihtout hassle and scaling.
    Dec 16 2014
    Irvine, CA
    Just being able to use wideband sensors for fueling is huge. E85 flex fuel would be super nice.
    Feb 19 2011
    Earth
    I have 121 ecu plugs in stock and ready to ship fo those wanting to make plug and play harnesses
    Sent from ...
    2000 Achat S4
    Jul 04 2012
    Woodbridge, VA
    Huh ? Flex fuel is nothing new to me7.
    Jan 05 2010
    Quote Originally Posted by vavJETTAw36 View Post
    I agree that flex fuel for me 7 is nothing new . I have yet to see a running b5 s4 with it. There was a mention of it in montys thread , but there hasn't been any updates regarding flex fuel.
    Jul 04 2012
    Woodbridge, VA
    I run an e85 tune. Plenty of s4s on here running it.
    Jan 05 2010
    Flex fuel is not ability to run e85. Flex fuel is on the fly switch between pump and e85 and all mixture in between .
    Jul 04 2012
    Woodbridge, VA
    Aaaaah my fault. Yes. Sorry I use "flex fuel" very loosely.
    Veteran Member Four Rings bobkatkat's Avatar
    Jun 07 2012
    North of the 49th parallel
    Is there anybody running a MS3 on an S4?
    We have been fooling around with one on another track car (ACR SRT-4) and it has been great. We have been using it to dick around with some things. Put a Maf in and a cross over table to go maf-less past 2k (makes the car easier to live with off track at idle, and 1st, 2nd and reverse). Real flex fuel. Really unlimited amount of sensors can be added and logged or used. Meth injection control, fail-safes, meth content etc. Even looking at it to do some active aero bits. I know that it is mostly DIY but the documentation is really detailed(big city phone book when printed out).
    Sep 13 2014
    Land Cruiser HDJ81
    Quote Originally Posted by bobkatkat View Post
    I've never seen it, but it's certainly possible. You can run just about anything with MS3 providing you have the knowledge to set up all the requisite triggers, sensors, outputs. It's a very powerful ECU.
    Dec 17 2014
    San Diego CA
    Im leaning more towards the ms3, and the AEM infinity 8 comes in a close second. Does anyone have any first hand experience when it comes to tuning these different ecus and the useability of the companies software and customer support ect?
    Jun 07 2012
    I can't speak about the other but the MS3 software is http://www.tunerstudio.com/index.php...-studiohttp:// By EFI Analytics. Support is really good and the free manual is huge and comprehensive. Smarter people than me swear by VEMS, so that would also be something to look at.
    Sep 11 2009
    NE
    Would be nice if there was an adapter to convert ME 7.1 plug to specific standalone without a need to do a lot of custom wiring around the bay. Just a simple drop and done.
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Quote Originally Posted by julex View Post
    As I said earlier my friend can make those, just tell me what do you need :)
