I am trying to replace my front struts but can't get them out. Getting the lower bolt out was easy and I removed the two plugs up top and got those nuts off easy too. But I can't get the strut to clear the lower control arm to get it out. The pinch bolt is pretty well stuck so I would rather not mess with trying to get these out again. Last time I had to use a torch which killed the control arms. Anyway just seems if they made a pass through to get to the two bolts holding the strut in I should be able to get this out. Searching suggests removing the swaybar links which I can try but any other suggestions?
