OK so finally got around to some of this. Replaced the dipstick tube although I'm not convinced mine was completely cracked - it may have just been some residual oil from something else but went ahead and did it regardless. I also replaced the check valves with US plastics for #s 5 and 6 in
this thread. I went to replace #1 as well however when I did I found the US Plastics valve wouldn't span the gap between the two hoses as both are fixed in place on either side. Did you extend one of these hoses to bridge it? Anyway when pulling the OEM valve out I found the white side had complete cracked off into the hose so had to pull the piece out with needle nose pliers and ended up replacing it with one of the OEM valves from 5 or 6 for the time being. I didn't have time to brave the other 3 and with the cracked #1 valve I wanted to see the results. I haven't been able to go for a drive yet but will do that this week and post results.
So quick edit - I looked through the main thread some more and found
this post which at the very end has a picture that appears to be how #1 was handled. Just checking on what type of hose you used (as you had mentioned heater hose wasn't always a good fit), especially with the 90 degree bend.
Also you had mentioned the coil pack and injector wires - both of those were replaced when the car went kaput on the freeway. They replaced the suction pump first and when I went to pick it up it wouldn't turn over and, as I thought the coil pack wires had finally gone so the shop I had been towed to went ahead and replaced those as well and the guy is familiar with these engines so he did the injector wires at the same time so those are off the list for now.
FYI after I cleared the codes last time the CEL came back (as expected) but with some slight variations. I pulled these after doing the above work and then cleared them to see what comes up next:
VCDS-Lite Version: Release 1.2
Sunday, 07 August 2016, 13:28:42.
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0002
Coding: 0016751
Shop #: WSC 63351
VCID: 749B5FD357A3
6 Faults Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded
17519 - Shareware Version. To Decode all DTCs
P1111 - 002 - Please Register/Activate - Intermittent
17978 - Shareware Version. To Decode all DTCs
P1570 - 008 - Please Register/Activate - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
16687 - Shareware Version. To Decode all DTCs
P0303 - 001 - Please Register/Activate - Intermittent
16688 - Shareware Version. To Decode all DTCs
P0304 - 001 - Please Register/Activate - Intermittent
Readiness: 0000 1001
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8E0 927 156 P
Component: AG5 01V 1.8l5VT USA 0910
Coding: 0001002
Shop #: WSC 63351
VCID: 3B09B4EF3A7D
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04277
Shop #: WSC 06435
VCID: 2D2D8AB7F409
