Results 1 to 13 of 13
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    Differential Fluid Change
    What do I need to change all of the fluids for the Transmission/Front Diff and, Rear Diff?
    Regards
    Apr 17 2016
    kc
    10/17mm allen socket, handpump with long tubing. 3 liters of 75w90 GL4 for the trans/centre diff and 1.5 liters of 75w90 GL5 for the rear.
    Jun 16 2011
    996tt
    MA
    Thank you!
    OEM Fluid part #s?
    Apr 17 2016
    kc
    Not sure. I used redline MT90. Awesome stuff.
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Quote Originally Posted by hightime80 View Post
    Except they say right on the bottle "MTL, MT-85 & MT-90 are not for use in differentials with hypoid gears" which doesn't work with our hypoid transmissions.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Feb 05 2014
    Apr 17 2016
    kc
    https://www.ecstuning.com/b-assemble...g/n10037106kt/
    Used mt90 in my trans. It's gotta be better than the 136k miles worth of OEM fluid that came out. Shifting smooth with no complaint so far. Will update if my trans falls out!
    For the rear diff I just used some castrol gl5 75w90 from the local autozone.
    Feb 05 2014
    Trust me ECS has been wrong many times. When it says on the bottle not to use it I'd like to think they know what they are talking about.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Dec 25 2004
    Earth
    Motul Gear 300!
    GL4 and GL5!
    Same for gearbox and rear diff.
    Because its synthetic!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Mar 05 2013
    CA
    What about this for the gearbox, and something else for the differentials, such as Motul Gear 300?
    Dec 25 2004
    Earth
    Quote Originally Posted by Spike00513 View Post
    Where does one acquire such magic oil?
    Seems they also make a 75w-85 and a 75w-90!
    Also a Syn 5...full race, full synthetic 75w-90!
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by MikTip View Post
    advanced automotion sells the Fuchs oil, I'm friends with a distributor here so he gets me Fuchs oil, the sintofluid is great oil.
    as for the rear diff, any GL5 75w90 synthetic will do, the rear diff of these cars don't care what fluid is in them unlike the transmission.
    Dec 25 2004
    Earth
    Quote Originally Posted by seanf86 View Post
    Exactly! All these "exotic" oils....the rear diff doesnt care...
    The front gearbox's owner/driver cares...
    has to shift a certain way...
    mask hundreds of thousands of miles wear...
    No "magic" oils out there!
