Results 1 to 7 of 7
    Nov 30 2015
    Q5 Brembo's as SQ5 rear brakes?
    I have a set of Q5 Brembo's can I swap out the stock SQ5 330mm rear calipers and rotors for the 4 piston Q5 345mm Brembo's? Is it possible?
    2011 S4 Premium Plus-Sprint Blue
    2009 Q5 Prestige-Ibis White
    2015 SQ5 Prestige-Moonlight Blue
    2002 A4 Avant-Light Silver Metallic
    2002 A4 Avant-Dolphin Gray Pearl Effect
    1969 Mustang Fastback-Acapulco Blue-62B 1 of 5,958
    Mar 13 2014
    Newcastle, England
    In theory yes, however you will need to retain your OEM caliper also to retain the e brake and the rotor probably has a different offset.
    More work and issues than it is actually worth.
    This is a picture of a Vandit Performance kit that my frient fitted to his B8 A4
    Euro SQ5
    C6 Carbon Interior, Exterior and Engine Bay
    Custom yellow stitch and yellow seatbelts
    StillStatic/AH Exclusive Race H&R with custom Air bags (25" ground to fender)
    Aiflift 3P Management
    C6 Carbon Chassis mods
    DTUK Tuned 370Bhp 774Nm
    Rotiform DUS 22x10.5
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    run a dual caliper setup with a brembo parking brake
    its a LOT of work to retain e-brake.
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    I was talking to Mops about this the other day.
    If They made a Brembo GT kit that gave you the Front & Rears with same style rotors and good pistoned (4 minimum) rear caliper, that would retain parking brake, I'd be all over it. I hate mis-matched rotors.
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Quote Originally Posted by ThunderDent View Post
    you can probably piece this together yourself fairly easily if you are willing to spend the money. they sell a separate parking brake caliper. something like this http://www.2wheelpros.com/brembo-oe-...FRCRaQod4JEI-g
    Mar 13 2014
    Newcastle, England
    The brembo parking brake (as found on the R8 and Lambo's ) is not electronic though so how would you get round that issue?
    Hence why the above kit retains the OEM caliper for the handbrake
    Euro SQ5
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    swap to a manual, hydraulic handbrake for all the drifts!!!
    jk you're right i forgot the B8+ all have electric parking brakes. retaining the OEM rear caliper is pretty smart that was my plan when building a rear BBK for my b7. but that was b/c i was cheap haha
