Results 1 to 16 of 16
Thread: 6000K bulbs?
    Established Member Two Rings Phrost2.0's Avatar
    May 02 2014
    Green Bay, WI
    6000K bulbs?
    Anyone have experience with them? I'd like to see some pictures if someone has then. I've always been a sucker for the newer Acura/ Lexus headlight temperature. I feel like 6000k would have the perfect amount of "daylight" simulation at night giving a slight blue tint without being ricey. Thoughts/comments/experiences?
    Veteran Member Three Rings zps123's Avatar
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    Stock is 4500 or 4300k I believe. Aren't new Acura headlights LED? Xenon is a little different.
    2015 Audi SQ5
    Brilliant Black|BO|Black Nappa|B&O|NAV|KW HAS
    Past: '14 Audi S4 | '11 VW Tiguan
    May 02 2014
    Green Bay, WI
    I've seen tons of picture of what they allegedly look like but I'd like to see some on the car. A shot with 6000k vs OEM from inside the car. I believe you are right about Acura headlights being LED now but I want a similar look. Someone's gotta have em! I saw some shots of what they look like facing towards the car but I want an interior view if possible.
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    Quote Originally Posted by Phrost2.0 View Post
    Google is your best friend...
    2015 Audi SQ5
    May 02 2014
    Green Bay, WI
    That's not an S4..
    I'm looking for a example on an S4 B8/B8.5.
    Oct 20 2008
    Denver
    i'm running 6000k HID bulbs in mine and it's pure white. not even a hint of blue like that fake shit ^^
    Dec 30 2012
    2008 Gsxr 600 track beast
    Mountain View, Ca
    Subscribed. I've kinda wished I could have a cleaner / purer light output than stock...
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    I'm running philips x-treme vision now @ 4800k, the reason why i went for 4800k instead of 6000k is that 6000k is just not bright enough. I have yet to see any bulbs that's rated 6000k but also put out >3000 lumens.
    For op, i definitely suggest x-treme OR orsam cbi, they are two of the best ones on the market and matches the DRL extremely well (I set my DRL brightness to be 40% at night and the color of my hid just blends in, if your DRL brightness is at stock the hid is even more blueish than led DRLs)
    The 4800k for the philips is miles whiter than stock @ 4300k and noticeable brighter as well after burn-in.
    If you really are going to get 6000k, hidconcept used to have 6000k bulbs from philips and orsam, but not right now. The only 6000k bulbs they carry now are from Blesk, which is not very good compare to the two companies above. You'd better wait for a while (may be just a week or so). hidconcept often has a discount and sometimes give AZ members a better discount, like right now.
    BTW part of the reason why Acura has a better light color output is from the clear lenses they are using. You can bake open your headlights (or ask a shop to do it, i.e. Yelp "headlights modding") and swap your lenses with ZKW-R clear lenses. You will notice the difference immediately. OR you can just simply buy ecodes (euro spec headlights) which have better lenses than NA spec headlights (not as clear as clear lenses though, but theoretically safer than clear lenses)
    There is an ecode group buy going on right now: http://www.audizine.com/forum/showthread.php/713604
    update: for your reference, here is my review of the philips x-treme vision bulbs, NOTE: That was immediately after install, after burn-in, it becomes a lot whiter (cooler color) and a little brighter.
    http://www.audizine.com/forum/showth...5#post11466405
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    ^ Great reply. I was going to explain those exact points. I am also running the Philips X-tremeVision. It was between those and the Osram Cool Blues that were also mentioned.
    Probably the most important piece there is the lumens portion. If you are used to your stock HID's, you actually might be disappointed with the usable light output 6k gives. Higher kelvin = lower lumens, and as yjpm mentioned above, 6k will only give you >3000 lumens.
    For reference
    4300k OEM: ~3,200 lm
    Philips X-tremeVision: 3200 ±450 lm (up to 50% brighter than OE)
    OSRAM Xenarc Cool Blue Intense: 3200 lm (up to 20% brighter than OE)
    6000k Philips Ultinon- 2700 ± 250 Lm
    May 02 2014
    Green Bay, WI
    Quote Originally Posted by AudiTFSI3o3 View Post
    Can you take some night time pictures of a POV from the drivers seat? Also some pictures from the car facing a wall?
    I would really appreciate it
    Nov 15 2015
    Central NJ
    I have the Phillips on my s4 and the osram on the wife's car. The Phillips are definitely brighter and a more white than oem. The osram on the wife's car are pretty close to the same brightness, and closer to the look you're going for. Swapping out the lens for a zkw might help as well, since they are completely clear. There's a write up on that. Haven't done it as I'd rather not pull my headlight housings apart. $40 though, easily worth the cost imho
    Established Member Two Rings boogie610's Avatar
    Oct 15 2015
    2011 Honda Crz , 2005 Subaru STI, 2007 Jeep Liberty
    New York
    My friend recommended mtec bulbs for my s4. He has a set in his M . They were about $200 ish for the set. I ordered diamond white and ended up receiving a aqua blue looking color. Mind you this is from mtec themselves. They look fantastic. I think a lil brighter then stock. I have them for about 2 years and no issues. I can put up some pictures as soon as I get my car back from getting wrapped. I also upgraded my fog lights to match. Have to say it looks real good at night..
    Oct 20 2008
    Denver
    sorry just saw this. i'll try to take some tonight
    May 02 2014
    Green Bay, WI
    That would be very much appreciated!
    Oct 20 2008
    Denver
    Phillips 6000k bulbs
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    Go with 5000K. It's a closer match to LED bulbs than 6000K, and you won't lose much brightness either.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
