Hello, I've only posted on here a billion times the last few months haha it's always something with my s4 but I love it regardless.
Anyway, I finally had it running great again... I just had to replace the flapper inside the intake manifold and after a week of no problems... Now it is running terribly. I don't have a Ross tech cable but I do have the foxwell scanner with vagcom and I am getting a few codes as well as some misfiring in cylinder 6.
The codes I get are as follows:
16590- injector cylinder 6 (n84) circuit malfunction p0206 -static- interruption
16684- random multiple cylinder misfire detected p0300
16690- cylinder 6 misfire detected: p0306
18048- internal contr. Module (eeprom) error: p1640 -static- short circuit to another valve
I had vagcom running live data while the car was running and it's only detecting a misfire in cylinder 6 when its idling, if I give it gas in neutral it stops misfiring until I let off.. When I try to drive, there is serious power loss, a flashing check engine light, and the tone of the exhaust is totally different. It almost sounds like there's a towel stuck in the cat. I replaced the crank position sensor today with a brand new one, I replaced the coil packs on cylinders 5 and 6 with new ones, as well as moved the spark plugs to different cylinders too but it still only misfires in cylinder 6. I also removed the fuel rail and cleaned off each injector with no results.
This has me totally confused and idk what to do really at this point so I'm hoping someone has some insight on what to do next. Thank you!
