Results 1 to 3 of 3
    Sep 05 2014
    Ottawa, Ontario
    Clear lens swap question
    So I swapped the sti-r lens into my bi xenons without any luck. TRS then suggested the Zkw-r lenses. They are better, but I find the actual light output less than with the stock lenses. Up against the wall, the ZKW-R lens has a better cutoff but blotchy light output. I used two washers to space the lens as I read here. Any tips? Is this a focus issue? Or am I just wasting my time?
    Dec 19 2011
    Colorado Springs
    Are the projector buckets burnt?
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    This is what my car looks like with STI lenses. Try my DIY.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
