Results 1 to 14 of 14
    Senior Member Two Rings trevor51590's Avatar
    Dec 18 2007
    '21 S4, '21 Q5
    Hands Going Numb from High Frequency Steering Wheel Vibration
    Have any of you guys had an issue where your hands start to go numb from high frequency vibrations at speeds from maybe 40+? I'm thinking balance or alignment but the car is CPO and just had new tires/alignment before I got it. I had a B8 S4 before this and never had this issue.
    I've had a bad balance before and it doesn't really feel like that, although maybe it's out just enough to cause this issue. That would lead me to alignment, but the car tracks straight and the steering wheel is dead on. I haven't noticed any feathering or uneven wear after about 4K miles. Checked the tread depth at various points on all the tires and they're all even. Only thing I could think here is something minute out of balance, or the tires setting into a harmonic with the alignment. I really don't remember it doing this when I test drove the car, but the new to me car effect may just be wearing off.
    I know there is a known issue with these electronic steering racks, but is high frequency vibration a symptom? The nearest dealer is over an hour away so I want to make sure to check out what I can before making the trek.
    '25 RS6 Performance | Daytona Gray/Congac/Black Dinamica | Executive | Black Optics | RS Sport Exhaust | RS Driver's Assist | B&O
    '21 Q5 Premium Plus | Navarre Blue | Nav
    '21 S4 Premium Plus | Daytona Gray | S Sport | 034 Stage 1
    --Gone but not forgotten--
    '23 RS5 Sportback | '18 A4 Premium Plus | '18 Q5 Prestige | '13 S4 Premium Plus | '11 S4 Premium Plus | '06 A4 2.0TQM | '99.5 A4 1.8TQM
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Sounds like she needs a balance, but even with bad balancing tires, my hands have never give numb like that. The only time was when I was using the hammer drill for too long.
    Senior Member Two Rings Lockon_B7's Avatar
    Oct 17 2014
    New Jersey
    Sounds like it might need a road force balancing.
    2016 A4 auto P+ Daily driver
    2016 S3 Sepang Blue Sold
    2009 A4 2.0T, 6MT, P+, Sport Package, Meteor Grey. Sold
    2008 A4 2.0T 6MT RIP
    Apr 04 2012
    MSP
    Engine mounts bad?
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Maybe you just have carpal tunnel?
    2021 Audi S4, P34 Intake
    Dec 18 2007
    '21 S4, '21 Q5
    Quote Originally Posted by MrFunk View Post
    Engine mounts bad?
    Not going to rule it out, I haven't pulled out the belly pan to check for fluid. I do have the audible solenoid knock (I had it my by B8 as well) and I'm not sure if it's normal or not. There's no associated code though.
    My hand's definitely feel like I got done using a power tool (although not to that extent, but its bad enough to notice it after I drive the car)
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Try Hunter 9700 road force balance before you try anything else.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    May 20 2010
    Check your wheels too--I had HORRIBLE vibrations around 40 mph, even after road-force balancing it several times over. Turns out that the wheel had a crack in it. So something to think about.
    But... from the speeds, part of me is leaning towards engine mounts, as someone said above. A visual inspection won't cost you anything but a bit of time, so it's not a bad place to start (along with the inside of the wheels). My brother had a similar issue and his mounts were it.
    May 17 2012
    Houston, TX
    Hands going numb is probably more of a health issue than the car. We've all had some vibrations at some point and you should never experience something like that. May want to get checked out.
    Dec 18 2007
    '21 S4, '21 Q5
    Quote Originally Posted by AKPS4 View Post
    I appreciate the concern. My hands aren't actually going numb, but it's the best way to describe the tuning fork sensation my steering wheel is putting out. I promise it's not a health related issue
    I'm going to rotate the wheels today and see if it's tied to the ones on the front. If so - balance. If not, on to the engine mounts/rack
    May 17 2012
    Houston, TX
    Engine mount leaks should be easy to see. You'll see brown/black staining all over. Someone posted a good photo of theirs.
    How many miles? Maybe worn bushings causing some vibration.
    Need tire rotation? My all seasons cause a little more vibration than my PSS tires. Don't know why but it just does. I rubber is certainly not as soft as the PSS and may be one of the causes.
    Unfortunately these tiny vibrations are annoying and may never be found without having replaced lots of little things.
    Good luck and let us know what you find.
    Junior Member Two Rings
    Nov 24 2009
    2012 S4 P+, 2013 Q7 TDI P+
    Dallas, TX
    Start with checking cold tire pressures and reset them in MMI. Both our S4 and Q7 go crazy with uneven tire pressures.
    Sent from my HTC 10 using Tapatalk
    2012 Audi S4 Premium Plus
    2013 Audi Q7 TDI Premium Plus
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Check the steering wheel position. Is it set to high, meaning are your hands above your shoulders while your driving. Could be impacting blood flow to your hands because they are elevated and that would feel like what your describing. Shacking would be visible in the steering wheel.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Engine mounts bad?
    I thought there was a cel to warn you when they go bad? Still blows my mind that the mounts upon which the engine sits are so poorly designed that they go capoot on these cars, never encountered that before w any vehicle in my life.
