Results 1 to 30 of 30
    Mar 02 2016
    E36 BMW
    Athens Tennessee
    Lowering with stock shocks
    I am trying to decide my most cost effective option. My first thought was H&R sports on stock shocks. Its my wife's daily driver a 2016 base model A3. I don't want to replace the shocks within a year. The car will see at least 20k a year in mileage . Would a quality set of coil overs be a better Investment? Any advice would be appreciated. Thanks.
    Veteran Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    I just installed Bilstein B14 coilovers for $1000 and it honestly rides better than stock, lowers a good amount, and handles way better now.
    Sent from my SM-N910P using Tapatalk
    Instagram: TonyConQuattro
    Apr 11 2012
    "do it right or do it twice" definitely applies to miss-matched-springs+shocks vs. a quality set of coils.
    Feb 18 2016
    Infiniti QX60
    SD
    I didn't particularly care for any of the current coil-over setups as they do not allow for height adjustment other than compressing the spring. Which in my opinion doesn't give you the best ride because you are increasing the preload on the spring and also limiting the travel of the shock. Now if you do not plan to "slam" the car and use the coil-over as designed I'm sure it will be fine, I just prefer the ability to adjust height and preload separately. I went with an Air ride setup instead.
    Apr 12 2016
    North America
    Quote Originally Posted by will13k7 View Post
    +1.
    OP, since you drive 20k miles per year, you should go matched springs + shock (Eibach prokit + Bilstein B8 = Bilstein B12) or get the Bilstein B14 if you care for height adjustability.
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    I think if you put a set of springs in the car, w/o doing some kind of performance strut designed for lowered cars you ae going to hate the ride within 3 months. Do a set of coilovers and you won't be sorry. Just don't try to slam the car.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    If you do a minimal drop (0.75") on linear springs you should be ok with OE mag ride shocks. I am happy with mine. I first did H&R progressive springs and it was terrible.
    Full coilovers would no doubt be better, but 10 x the cost
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by VWVW View Post
    +1.
    We just did two of these setups, one on an S4 and one on an A4. Both B8.5's and the cars rode great afterwards. Its a massive improvement over the stock suspension.
    Thanks,
    Greg
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    It is very difficult to properly dampen a progressive spring with the stock shocks & struts. We offer the only linear spring for the A3/S3, which is designed with rates and travel specific to the OEM springs & struts. Many users have noted a much improved ride quality with this setup when compared to other aftermarket options
    http://www.emmanueledesign.com/colle...nt=22065145927
    May 21 2015
    Pacific NW
    Quote Originally Posted by EmmanueleDesign View Post
    I agree with this completely. And the ride height is perfect - just the right amount more aggressive without any fender tuck.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2008 BMW 535xi (sold)
    2006 A3 2.0T (sold)
    Apr 12 2016
    North America
    Quote Originally Posted by Excelerate Rep View Post
    Thanks,
    Greg
    The Eibach Prokit + B8 (B12) or B14?
    Mar 04 2010
    Pittsburgh, PA
    Fwiw I raised this with my local service manager and he did not think springs would cause premature shock wear. I went with Emmanuel design and couldn't be happier with the ride. Very similar to stock perhaps a bit less harsh.
    Feb 14 2014
    Audi's
    Branford, CT
    B12.
    For those of you out there that are just looking for springs to lower the vehicle the ED springs will suffice and work well for you.
    But do you track your car? Drive super aggressive on the street? Take a look into an option from a brand we embrace and distribute to the North Americas. MSS Spring kits.
    DCC designed, track tested, customer approved. We have a few cars running these adjustable springs specifically designed for DCC using the OEM technology locally and have had very positive results. Due to arrive within the month on our shelves.
    You can view this link for some information, and as always I am here to help.
    http://www.audizine.com/forum/showth...3-S3-PRE-ORDER
    Thanks,
    Greg
    Mar 02 2016
    E36 BMW
    Athens Tennessee
    I cant find the bilstein b12 for an 8v A3. I dont think they are available .
    Senior Member Two Rings FabianS's Avatar
    Jan 29 2015
    Calgary AB
    I also went with the Emmanuel Design springs and am very happy with them thus far.
    Mar 02 2016
    E36 BMW
    Athens Tennessee
    So on a non mag ride, FWD only A3 the Emmanuel design springs will lower 1.75 and the shocks will have a decent life span?
    Apr 12 2016
    North America
    Quote Originally Posted by lettheirberock View Post
    You have to get the Eibach prokit springs (recently launched by Eibach US) and the Biltein B8 shocks separately. I have previously emailed Eibach Germany and they confirmed that the B12 kit uses Eibach prokit springs and Bilstein B8 shocks. I have double checked the part numbers to make sure that is the case. If you do not believe me, feel free to email Eibach Germany.
    While I think the Emmanuel design springs are good, I have serious doubt about its impact on the standard nonsport A3 shocks. The shocks are constantly under an additional compression of 1.75". I highly doubt that the shocks will last long. Given that you drive 20k miles a year, I'd suggest you get shocks along with it.
    Mar 02 2016
    E36 BMW
    Athens Tennessee
    Thank you
    Apr 12 2016
    North America
    Thank you
    No worries.
    BTW, another path may be to get slightly used OEM S3 springs and shocks. Someone seems to be selling them right now on this forum.
    http://www.audizine.com/forum/showth...way-bars-links
    Mar 02 2016
    E36 BMW
    Athens Tennessee
    Thank you
    Eibach shows springs for quatro only
    Apr 12 2016
    North America
    Yes, EibachUS only offers springs for quattro only.
    As an alternative, you can import from Eibach Germany pro kit springs for the 1.8TFSI FWD A3. There are many international vendors that sell Eibach prokit springs. The springs will be linear and lowers just 30mm. You just need to make sure you get the right part number (for the saloon and 1.8TFSI FWD A3 8V).
    Feb 21 2016
    B14 I'm telling you best value you can possibly get. For $200 more than a strut and spring combo why not get a more capable coilover with height adjustability. Keep in mind it takes just as much labor to install springs. Yes they are fwd compatible too.
    Apr 12 2016
    North America
    Quote Originally Posted by INYAUDI View Post
    +1.
    OP, since you cannot get the B12 easily, I'd probably go with the B14 as well if I were in your position. The only reason why I prefer B12 over B14 is due to the Northern snowy climate, so I do not want to go coilover.
    Feb 21 2016
    VWVW where up north? Im up in NH and we get hit hard, they are coated so I'm not worried.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    i personally have the b16 and have a friend with the b14
    for $950 you can't beat the b14 and for $1500 i am very satisfied with the b16 kit
    pm me if you want to know where we found those prices
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Apr 12 2016
    North America
    Northern Neighbor to the US.
    Too much snow....lol
    Mar 02 2016
    E36 BMW
    Athens Tennessee
    That's what i'm leaning to.
    Feb 21 2016
    If you do the install yourself feel free to PM me for questions relating to bolt/nut part numbers; or for any helpful hints that forum threads / youtube vids did not mention.
    Mar 02 2016
    E36 BMW
    Athens Tennessee
    That looks great. Is that set to top height or lower?
    Feb 21 2016
    I couldn't tell you exactly how much drop I have as I did not measure from wheel center to fender beforehand. Maybe someone can chime in on the exact amount based on the info I provide. B14 Coilover setup has 2" max drop. I have 16 or 17mm 'dropage' left on the collar in the front and 13 or 14mm in the rear. Still has the rear rake but ever so slightly. At this height I can still get out of my driveway which has a 3" curb to it, virtually worry-free. Wheel specs: 17x7 et48 225/35r17
    There's a bunch of room in the wheel well still.
