    Senior Member Two Rings X-ZZ4's Avatar
    Jun 29 2015
    Oregon
    Why does my car think it is getting 30mpg when it is not even getting 20mpg?
    It's always read high, but my display is usually very dim so I never pay attention to it anyway. But sometimes, usually when it is colder, the display works ok for a while.
    Regardless, it was always displaying around 28mpg. I've owned it for a year now, and never reset it. Another reason to ignore it...totally false.
    But about 2 tanks ago, the display was working good when I got gas, so I decided to reset it. I was curious to see what it would read after a reset.
    Now....about 2 tanks later....my display decided to work well again today. It now reads 30.2mpg. I always do simple math and manually calculate mileage when I fill up, and it's usually about 18mpg.
    So why is it so far off? Is this common? Is there a fix?
    2002 Audi A6 2.7T Quattro
    K04's, Solo Motorsports Intake with 85mm MAF, Bosch 550's, Stage 3 Tune, H&R lowering springs, TSW wheels, other misc crap.
    Recently Gone:
    1999 Chev Corvette - Nitrous, 499RWHP
    2004 Pontiac GTO - Nitrous, 528RWHP
    https://www.youtube.com/watch?v=fQ2r5QQ6jaw
    Jun 29 2015
    Oregon
    Ok....I know.....search is your friend.
    I searched and only went a couple pages deep before posting because I was only finding crap on MPG of the newer cars. So I posted. Then I kept going deeper in the search and found this....
    Quote Originally Posted by MonkeyKing
    The range of adjustability in VAG-COM is 85%-115%. Mine was reading about 14.5 mpg when I really get 20mpg. I adjusted the consumption to 85% and now it shows 17mpg. So, I doubt you will be able to lower yours that much. But try to make it 115% and see what happens. Copied from the wiki:
    "If you change fuel injectors, your instrument cluster will estimate your fuel consumption incorrectly. Use VAG-COM to adjust it by going to Instrument cluster (17) -> Adaptation (10) -> Channel (03).
    Unfortunately, you can only set it to a maximum of 115%. Default is 100%.
    If you have access to ME7.x tuning tools, you can completely fix cluster consumption by adjusting the KVB 1x1."
    I have 550cc fuel injectors. So I assume this is the cause of this, and there is nothing that can be done. Not a big deal....I don't care much, was more curious than anything.
    Does everyone agree? Is this why my reading is so far off?
    http://www.audizine.com/forum/showth...lay-proper-MPG
    Recently Gone:
    Veteran Member Three Rings vlangs's Avatar
    Nov 09 2013
    Manhattan
    my car gets about 14mpg
    I don't have anything to add to this conversation i just wanted to complain
    Jun 10 2013
    United States
    MPG is miles per gallon. The computer calculates miles based off of speedo. Computer calculates gas used based of the time the injectors are open. For a given size injector at a give pressure it will flow a certain amount of fuel depending on how long the injector is open. The computer is calibrated for a certain size injector and fuel pressure. It then captures injector pulse width and frequency to detemine gallons used.
    So what happens if the stock injectors flow 300cc/min and are replaced with 600cc/min injectors. The ECU holds the 600cc/min injectors open half the amount of time. If the MPG computer is still calibrated for 300cc/min then the computer is going to think you used half the fuel that you actually uaed an therefore double your MPG.
    Established Member Two Rings stuklr's Avatar
    Feb 18 2006
    Middle of nowhere
    Tune is setup incorrectly for the current hardware.
