Results 1 to 9 of 9
    Jun 01 2016
    columiba/mo
    1-2 shift grinds sometimes
    Hey everybody, been having some problems with my 1-2 shift on my 2001 s4. Seems when I get on it in first gear and push in the pedal to shift into second it will kinda grind sometimes. Other times it'll do it when I drive it normally an try to shift it into second, as soon as I press the pedal it'll grind. Now it only maybe does this once a week. Do you guys think it could be my clutch, or would it be something more complicated such as the synchros.
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Definitely the synchros. You should be extra gentle with it til you can have it fixed as it's only going to make it worse the more it grinds. I had the exact same issue and it got real bad, real quick. I replaced both the synchro and 2nd gear with OEM and have zero problems now. Depending on your car and its power level, you may want to consider a TDI 6th gear as a 'while you're in there' upgrade too.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Shiiiiiit, might as well get an RS4 third too
    May 16 2008
    Quote Originally Posted by Zba View Post
    I mean, while you're in there Hehe
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Maybe a good place to ask your guys' recommendation. My 4th grinds all the time. I can get it to go in without grinding if I double clutch and hit the revs pretty accurately. Then it will go in. Downshifting into 4th is not an option.
    What would you all replace? Whole synchro set and 3-4th collar? Which synchro set to go with? Upgrade 1-2 collar too? The car has 198k and since I do not know, assume the transmission is original.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jun 01 2016
    columiba/mo
    The thing is though it's not hard to get it into second gear at all, and when it grinds like the shifter just falls into second really quick, makes the grinding sound and goes into second than. It rarely does it. If it's the synchros would it be better and cheaper to get a used reconditioned transmission or just get the 1-2 kit to replace the synchros and collar.
    Nov 05 2009
    Denver
    grinding is grinding and you need synchros. If you plan on keeping the car for any amount of time spending the 1500$ on a reconditioned unit from one of the vendors on here would be the way to go. Or if you are so inclined get the parts and build it yourself for around 800$
    May 16 2008
    South Texas
    Try changing the fluid.
    Veteran Member Three Rings Number54's Avatar
    Dec 04 2007
    Switzerland
    ^^^ This. Plus there are additives to help out. I had this done on my RS4 which grinds 1-2 and much less 3-4. For me, it made it a little better, not much. Has been like this for 2 years now, and it doesn't appear to be getting worse. Note that the grinding goes away when my car is warm, I don't know if that means my issue is less severe or not.
    • Audi A3 3.2 Quattro (8P)
    • Porsche 911 GT3 (996)
    • Audi RS4 (B5)
