Results 1 to 2 of 2
    Established Member Two Rings Wyd's Avatar
    Jun 29 2016
    WA
    Question Oil check valve maintenance/ Torque specs/ diy
    Im new to the forum so please let me know if this is in the wrong place :)
    I picked up an 2004 S4 just a couple weeks ago and I've decided to re gasket the whole top end and replacing oil check valves to reduce some clatter up there.(Also after checking my CarFax to find out last recorded engine maintenance was 50k ago.)
    Considering making a diy video for it while I'm at it. Those who are interested let me know.
    I was looking to see if anyone could provide me with some torque specs for re-assembly, i have very few as of now.
    I'm replacing:
    oil check valves, oil spray valves, all new filters and new set of plugs as well.
    Gaskets-
    intake manifold
    valley pan
    oil filter housing
    left and right valve covers
    lmk if I've left anything out you feel like would be a good idea while its apart
    Feb 18 2016
    Delaware
    ECS has a very nice write up on this procedure -https://www.google.com/url?sa=t&rct=...36593572,d.cWw
    Just did it myself if you have any questions feel free to ask.
    *t30 torx in the vally pan = 10nm (7.4 lb/ft)
    *oil filter torx = 10nm (7.4 lb/ft)
    allen = 22nm (16.2 lb/ft)
    *allens on intake manifold = 10nm (7.4 lb/ft)
    *allens on fuel rail = 10nm (7.4 lb/ft)
