Results 1 to 6 of 6
    Established Member Two Rings djkyky's Avatar
    May 27 2015
    24 Audi Q3
    Estero FL
    Fault Code interpratation
    Carista shows me two faults that appeared after installing Chipwerks and although it's says it clears the fault it is always there. Assume that is why it says permanent. Carista did clear the check engine light. Besides what it says what does this mean? Thanks
    OBD2 - permanent:
    P0240 - Turbocharger/Supercharger Boost Sensor "B" Circuit Range/Performance
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Check your connections on the CW box/supercharger sensors. It's possible it's not snapped in all the way, or worst case you have a faulty sensor on the CW box.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by djkyky View Post
    OBD2 - permanent:
    I don't think the OBD2 code has anything to do with the Chipwerke box. Do you get it when you scan the car without the Chip installled?
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    May 27 2015
    24 Audi Q3
    Estero FL
    No. Happened after install
    May 27 2015
    24 Audi Q3
    Estero FL
    The service light cleared but shows as permanent fault on Carista so I assume it there to stay.
    Jul 02 2013
    Can you find anyone nearby with a Vag-Com cable and check and see if it clears? Seems odd that you got a OBD port error, that would lead me to believe it was something with your interface. You could also email Murat at Chipwerke they are pretty good at helping.
