Haven't done it yet, but looks very easy, you just need to get the car up on jacks with enough room to maneuver under the oil pan with a torque wrench. You will need a torque wrench that goes inch-lbs, vs ft lbs and do the math, because the torque value is light on the fasteners. 6.6 ft-lbs. Most torque wrenches don't go below 20.
From a review I read, you'll want the car to drain with the pan off overnight to make sure you don't have oil contaminating the sealing surface when you do the final wipe down with brake cleaner. While I had my car on the jacks doing the 034 rear sub frame inserts two weekends ago I checked everything out prior to ordering to make sure it would be as easy as it seemed to be.
