Results 1 to 3 of 3
    May 31 2016
    Oneonta, AL
    B5 s4 trans problem. Please help!
    Car started this after a launch. I was still able to drive the car after this (drive 2-3 miles.) The car shifts out fine and no grinds In any gears. The input shaft spins, but hits a hard spot and stops. When it's in gear, I can spin the rear flange and everything is normal until it hits the hard spot, at that point the input shaft stops spinning and the front cv flanges spin backwards. I can't find any info on anyone else having this problem.
    Link to noise while everything was still in the car: https://youtu.be/waqhWou_AY4
    Link to show what input shaft is doing: https://youtu.be/sAKwDosmhgg
    Link to show trans: https://youtu.be/cspjiwktlNI
    Any info will be greatly appreciated!
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Time for a rebuild bud. Looks like you busted something.
    https://jhmotorsports.com/shop/catal...os-p-2317.html
    Or if you want to do it yourself: https://jhmotorsports.com/shop/catal...ar-p-2054.html
    However if you do it yourself you are likely going to need additional parts that we can source for you.
    May 16 2008
    South Texas
    Your going to need more than a rebuild. You have probably bent or broken a tooth on first gear. You will likely need a mainshaft, and first gear, and possibly a second gear depending on how mated it is to the main shaft.
