Results 1 to 17 of 17
    Apr 15 2014
    Ottawa/Gatineau Canada
    anyone know th specs for these 2 hoses? I need the I.D.
    I am prob just going to fab something up as mine are liking a bit worn. I KNOW when I remove them to check I.D. I will crack them so I am asking here before I remove.
    the first one is 06b 103 493 AB and is shown here
    the second is 058 133 785 B and is shown here. (yes I know it is cracked, this is a old pic and it has been replaced with a used unit from the wreckers)
    Here are both in there home :)
    Approximate overall length would be nice, but not required as I can do that with a string.
    Hopefully someone here has these 2 hoses sitting in a parts box ;)
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Aug 26 2005
    The ID for both hoses is the same as the tubing OD they attach to.
    Vorsprung durch Technik
    Apr 17 2016
    kc
    Great answer! Gave me a good laugh.
    Very true. Just measure the metal pipe's circumference then divided by pi then U've the answer.
    Apr 15 2014
    I will assume that you are assuming there is no "flare" on the end of the pipes and thus making the hose ID a bis smaller than the OD of the pipe. Or are you positive there is not?
    Dec 25 2004
    Earth
    034 sells the nice replacement versions in silicone...
    https://store.034motorsport.com/brea...b103493ae.html
    https://store.034motorsport.com/sili...d-b6-1-8t.html
    With clamps too!
    Or if yoou a baller $$$ Audi will take your money!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Changed mine on Saturday
    "Beep beeeep bloop boop" - R2D2
    Apr 15 2014
    [QUOTE=Willënskraft;11731417]Changed mine on Saturday
    Sweet, can you measure the ID of the old ones on both sides please?
    Oct 14 2011
    Norcross, GA
    [QUOTE=Luxus Panzer;11731539]
    Quote Originally Posted by Willënskraft View Post
    Uhhh I threw it away lol. Hang on let me see if I saved a pic. Standby.
    Do you need the P/N or the actual size?
    Apr 15 2014
    [QUOTE=Willënskraft;11731760]
    Quote Originally Posted by Luxus Panzer View Post
    Actual size of the I.D. (inner diameter)
    Oct 14 2011
    Norcross, GA
    Yup threw it away, these are the only remaining pics. Hope this helps a little.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    I measured the tubes leading to from my 06B 103 493 AE hose and calculated: inlet 23mm / outlet 28mm
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Aug 26 2005
    There may be a clamp retention ring formed into the tubing near the end of the tubing, but the nominal hose ID is the same as the tubing OD. The nominal tubing OD does not change at the ends of the tubing, it is the same OD over the entire length.
    Use a digital caliper to measure the tubing OD, or measure the circumference then divide by Pi as suggested by "hightimes80". A caliper will be a lot more accurate.
    Apr 15 2014
    Roger, I will dig out my caliper....r just order some from 034, lol
    Aug 26 2005
    The tubing that the "498A" elbow fits to is a different diameter than the tubing run length at the clamping length of the ends of the elbow, at least on the upper end.
    Apr 15 2014
    Sorry....huh? (lol)
    Can you rephrase that one please ;)
    Aug 26 2005
    Sorry....huh? (lol)
    I just meant the elbow with PN nnn zzz 498A has a different ID on each end,
    Apr 15 2014
    Outstanding, thank you.
    Now that our Canada post strike is put off, I will order from 034
