Results 1 to 10 of 10
    Established Member Two Rings stussy2870's Avatar
    Apr 04 2016
    Butler PA
    Replace Pads warning and "Brake" light on
    Hey guys,
    So i painted my calipers yesterday, while preparing etc, i removed the front caliper from the carrier. I also had to disconnect the wear sensor to get some free space to get the carrier bolts off. I did NOT replace pads (they are new) and when i was through doing all the work i reconnected the sensor and remounted it in the bracket.
    I started the car this AM to move it out of the wifes way and saw the referenced light.. How can i clear this?
    Thanks folks.
    2015 Premium A4 Sline 6M/T, Dinan PiggyBack, K&N Typhoon Intake, Comfort Drop Spings, Niche Targa 20x10, RS4 Grill, Slotted/Dimpled Rotors and some G2'd Calipers
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    I'm about to replace the brakes on my B8 for the first time, but coming from a B6 and B7, I think there are a few options:
    -Look for any way the circuit could be broken. That's how the sensor operates in the first place; maybe disconnect and reconnect the clip, inspect the contacts, check for frayed wire, etc.
    -VCDS should be able to clear it...?
    -Duct tape over the idiot light
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Apr 04 2016
    Butler PA
    Yaah, ill take the wheel back off and dcheck.. if its not fixed by unplugging it plugging it back in i'm just going to cut that wire and "fake" the connection. I keep a good eye on my brakes so im not worried about a dummy light..
    Thanks!!
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    If the light is ON, and the pads are good, then there is an open circuit in the wiring to the sensor. The sensor is just a loop of wire that gets cut-thru when the pad wears away. One end of the loop is grounded, the other end goes to the Instrument Cluster. I don't think you need VAGCOM to clear the instrument cluster "Worn Pads" light.
    Should be an easy fix....no need to "kludge it".
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    Yea, I wouldn't cut anything, I did the same thing as you. I unplugged the sensors, they might not be fully connected. disconnect and clean the ports, then reconnect and see if the issue is still there. I had no problems...
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Apr 04 2016
    Butler PA
    cool-- ill get back under there soon.. after a 13 hour day with those brakes, shields, wheels, rotors ect etc etc.. I've had about enough :)
    Apr 04 2016
    Butler PA
    Just wanted to update the thread.. Cleaned the connectors on the sensor and reconnected. Worked like a charm!!
    No more light :)
    Apr 04 2016
    Butler PA
    ....and as soon as i say it, the light comes back on. I ordered a new sensor from ECS.. Never replaced one, does the old one just get pulled out of the Calipers or do i need to pop the Pads out first?
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by stussy2870 View Post
    It's not on the calipers, it's connected to the pad. You should be able to pull it off with pliers and pop the other one on with out taking anything but the wheel off. Easy!
    Apr 04 2016
    Butler PA
    Cool!! TY!!
