Results 1 to 10 of 10
    Jul 24 2014
    '02 Audi a4, '87 bmw 325i cabriolet, '93 bmw 318is coupe, '98 a4 quattro 1.8t
    Denver
    AEB engine rebuild questions
    Hello, my friend crashed my 98 a4 quattro on a curb smh. He messed up my oil pan so the engine seized from no oil. I am about to get a block and throw in some new pistons, new rods, bearings, and crank shaft. my question is, will a rebuilt stock motor be good for building big turbo?
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    Depends on how much power you wants 300+ you need rods. The valvetrain I've seen go past 400. I'm iffy about that. But I know the pistons are good for 500. While its out upgrade what u can!
    Sep 12 2008
    South Central PA
    if you're getting another complete longblock, all you really need to do is hone the cylinders. Then new rings, rods (SCAT H Beams are drop in), and bearings.
    AEB pistons have 20mm wrist pins and are forged. Some crazy dudes have ran over 700hp on them, they eventually crushed the ringlands, but impressive for stock units.
    You only need to build the head if you are going to run a very large turbo that requires you to rev past 7,500 rpms.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    IMO, it is foolish to rebuild an engine and use the stock rods. They aren't very expensive and it is basically the only internal limiting factor on how much power you can produce. If you never end up getting a large turbo, oh well, you are out $400. Except for then you can sell the engine for extra because it already has forged rods.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jul 24 2014
    Denver
    Quote Originally Posted by Dan[FN]6262 View Post
    I am looking for about 300hp not looking to go too big. And when I build the head should I just change the valve springs? or valves and cams too?
    Sep 12 2008
    South Central PA
    if you're looking for 300hp, you can leave it all stock.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Jul 24 2014
    Denver
    well my head makes noise anyway so might as well. I am looking to throw maybe a k04 on there and some bigger injectors but the problem im having is tuning. Is it a custom tune or s there somewhere I can get a ready tune? been searching all over and cant really find an answer
    Aug 08 2014
    New Zealand
    Hello cool hope ur doing it all your self. But there is heeps of tuning compoies that do a ko4 file you have to get the ecu re chipped though send it in to one of them or go stand alone
    Revro.giac.apr.just surch aeb k04 file :) good luck but dont b silly and put rs6 turbo on or somthing in the gt35 area theres so many kits now
    Jul 24 2014
    Denver
    Quote Originally Posted by marka4 View Post
    gonna be doing it all by myself with some help from our employees (my family owns a mechanic shop) when I get this tune you told me about, will I need injectors and maf and all that? or just the turbocharger?
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    1)pick hp goal
    2)pick turbo
    3)pick tune
    4)buy supporting mods as set by the tune
    Your head probably makes noise because you have low oil pressure. If you're doing the head, replace exhaust valves with solid.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
