Results 1 to 3 of 3
    Jun 29 2016
    Denver area
    problem after rebuild - ATW 1.8t
    've completely rebuilt my ATW 1.8t - new main bearings, new rod bearings, new rings, etc. Put it all back together and into car - and WITHOUT serpentine belt (and accessories) - the car starts fine. I hear a tick-tick-tick coming from the head - but I think that is oil pressure that needs to build up the lifters. But since I don't have fan/water pump connected - I didn't let it run long (30 seconds or so). Timing all good - multiple checks.
    Now, here's the crazy part...
    Just as soon as I connect the serp belt - to drive the accessories (alternator, ps pump - water pump) - car won't start. I can leave all parts connected, but just remove the serp belt - car starts right up. But with serp belt - no start. It
    cranks, it sputters once or twice, but will not start up.
    Two questions:
    1. Could a timing issue be the tick-tick-tick that I hear when the car is running without the serp belt? Could timing be 1 tooth off and still start/run?
    2. If timing was off (say, by a single tooth) - but it doesn't start with "load" from serp belt being connected - but then would not start with serp belt?
    Just don't see anyway that a car that starts without the serp belt (and accessories it drives) would start without serp belt - but wouldn't when serp belt is connected???
    All accessories spin freely. Any help is greatly appreciated. Thanks.
    May 05 2016
    alaska
    It would still start if time was off by just a little but wouldn't run very smooth. Test your battery , it could be weak and doesn't have enough juice to turn all of that extra friction. I don't yhink your issue is timing though.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jun 29 2016
    Denver area
    Thanks for the reply, Casey.
    I was thinking the same thing, charged the battery - but had the same results.
    I tried something crazy...
    I took it all apart again, and re-installed the timing the belt - this time - applying the belt to the bottom of the crank, then the intermediate shaft, then the cam.
    Leaving all slack on the tensioner side. There are youtube videos showing both ways - I had not tried it this way yet.
    Then, I held the serp belt tensioner loose while I had my wife start the car - started right up - just as it had in the past.
    Then I slowly released the serp belt tensioner - and the car idled a bit more slowly at first - but then made it's way back to a normal idle (about 900rpm).
    After that, it starts right up every time.
    So, I don't know if it was the re-install of the timing belt OR the serp belt tensioner trick. My money is on the re-install of the timing belt - must have had
    something off by not even a tooth somewhere. Either way - it's working now!!
