Results 1 to 9 of 9
    Senior Member Two Rings dgreeen's Avatar
    Apr 09 2016
    CBRF4i
    US
    Coilovers closest to OEM ride/comfort
    Just wondering is there a general consensus for a recommended suspension that's closest to oem ride quality for coilovers?
    I know Bilstein are highly recommended but can be on the pricey side including H&R setups
    Any recommendations on the lower side?
    Established Member Two Rings PyroDonkey's Avatar
    Oct 08 2014
    Solo-Werks, I believe are most similar to stock for a cheaper option. I have ST's. They're firmer than stock, but still nice to drive on.
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by PyroDonkey View Post
    This
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Senior Member Two Rings jcdeng's Avatar
    Jan 04 2016
    2013 S4 DSG 2017 G63
    KWs, I made a mistake of following their recommended setting and only turn it 1 click higher (firmer). Feels too soft, same as oem s4 suspension feel but with a much lower ride height..
    2013 S4 prestige S-tronic, APR STG II with TCU tune, AMS Alpha cooler, ECS intake, Milltek Valvesonic, ECS skid plate, CR-15, RS4 front bumper, 034 X-brace, 034 RSB, KW V2, ONEighty custom headlights, custom 19" Work Emotion CR ultimate. Brembo 380mm front, ECS 2 piece rear.
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Sent you a pm OP
    Sent from my SM-G920T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Junior Member One Ring
    Mar 13 2013
    Rolesville, North Carolina
    I have ST coilovers on my A4 and I'm not happy at all with the ride comfort.
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Can't beat H&r coilovers.... especially with both sway bars!...
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Jan 16 2011
    Earth
    Obviously nobody read his post he said closest to OEM none of the setups mentioned so far are even close to oem ride.
    KW street comforts would be the best setup for what he is looking for.
    Sep 03 2012
    Lehigh Valley, PA
    Kw's had problems with rear spring sag... maybe their lesser quality st coilovers may be better... either way a quality setup will ride better them oem.. you don't necessarily trade all comfort for better performance...
