Results 1 to 10 of 10
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    FS: VAST Performance Throttle Body Up-Pipe with meth bung(s), clamps, hoses
    Up for sale is my old VAST Performance Throttle Body up-pipe. 2.5" Charge air pipe from intake to throttle body. 1/8" NPT bungs welded in for boost reference, methanol injection, etc. This has location for the MAP sensor as well as two locations for meth nozzles (pre TB).
    Includes original Vibrant silicon hoses and clamps.
    Made of Aluminum
    $55 shipped
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    May 09 2012
    Virginia
    What setup are you switching to? I am looking at doing a meth kit install as well. Thanks.
    Jul 15 2011
    Boynton Beach, FL
    Quote Originally Posted by jbain2 View Post
    Well since I finally installed my JHM FMIC kit, I had to eliminate this pipe from my car which essentially got rid of my meth injection since that's where my nozzle was plumbed into.
    So I went ahead and bought an IE throttle body plate to use as my new meth location and will probably pick up a dual nozzle kit (plus accessories) and hold it until I have the time to take the JHM post FMIC pipe out of the car to get an 1/8 NPT bung welded in. This pipe already has threaded bungs which makes install a snap if you are installing a "meth kit" and using your WW reservoir like I did.
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Free bump if you don't mind me asking why you're choosing to run dual nozzles? I have a kit that I'm waiting on a few part purchases that I need/want to install. Its the Snow Performance Stage 3 kit, I have the throttle body plate and was just going to run that one nozzle but I'd like to hear why you're going with more nozzles to see the benefit and perhaps go that route myself. I already have a front mount on so I could tap that as well. Thanks!
    Jul 15 2011
    Boynton Beach, FL
    Quote Originally Posted by i3oricua View Post
    More added benefits to lowering the IATs with the nozzle pre TB. With the nozzle post TB, the added gains are more from an increase in octane rating into the combustion chamber. Thus.... do both! :D
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by jerseybrian View Post
    Tech:
    As quoted by USRallyTeam.com "There's only but so much humidity that a unit volume of air at a given starting temperature can possibly absorb in a given period of time. A single very large nozzle will oversaturated the intake air with humidity. Then it will "precipitate". In plain English, that means that it will literally rain inside the intake piping as the fluid falls out of suspension and coats the walls. When this occurs there is no cooling, no octane boost, and the owner may run the risk of damaging engine internals.
    Mounting a nozzle just after the intercooler provides maximum distance travelled from the spray point to the combustion chamber. This ensures that the mist is carried by the air for a longer time period. More time allows for more complete evaporation. More evaporation guarantees more cooling.
    A throttle body-mounted nozzle works exactly the same way but in reverse. Less distance travelled = less evaporation = more droplets ready to turn to steam INSIDE the combustion chambers. This reduction in combustion temperature boosts the air/fuel charge's octane rating in a huge and very beneficial way. Of course, one may run a single medium-sized nozzle midway between the two ends. This delivers a compromised mix of both cooling and octane vs. maximum amounts of both. Special care must be taken to ensure that liquid droplets do not reach a drive by wire throttle body. (This is a non-issue for drive by cable throttles.)
    SO, should you run one or two nozzles? You should run two IF your budget allows. If not, you will still be delighted with the performance of a single nozzle. Size that nozzle responsibly to achieve excellent results."
    Then add another pump to spray water only on the FMIC itself and watch IATs drop incredibly because of the evaporative coolingof water on an IC.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jul 15 2011
    Boynton Beach, FL
    $50 shipped?? Any takers?
    Veteran Member Three Rings grassrootz's Avatar
    Apr 01 2010
    Tampa, FL
    PM'd
    -GrassRootz
    Jul 15 2011
    Boynton Beach, FL
    Quote Originally Posted by grassrootz View Post
    PM'd
    replied!!
    Jul 15 2011
    Boynton Beach, FL
    Sold!!!
