Results 1 to 11 of 11
    Established Member Two Rings pgiuliano98's Avatar
    Jun 22 2015
    Livonia, New York
    Sputters when given gas and rough idle after turbo replacement
    So I got a used ko3 from a member on here and put it in today. I'm 99% sure everything is back together the way it should be.. When I turned it on for the first time it had a rough idle and died when I gave it gas. Now this happens...
    After I give it gas the RPMs dive and I can feel the gas pedal pull towards the front of the car. Before putting this in I also tightened the wastegate so there were 3-4 threads left. At first I thought it was just the MAF... Anyone know what the f*ck is going on?
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    this looks and sounds like a TBA "Throttle body alignment" is needed
    one of those days... every day.
    Remember to change your blinker fluid it may go bad on you!
    Sep 13 2014
    somewhere
    has ur battery been unplugged for a while?
    Sep 12 2008
    South Central PA
    check for boost/vacuum leaks.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jun 22 2015
    Livonia, New York
    The battery wasn't disconnected and all vacuum lines should be in the same condition as before the swap. Could the wastegate be too tight and cause all this to happen?
    Registered Member One Ring mikejones701's Avatar
    May 17 2016
    New York
    Hey paz
    Sep 12 2008
    South Central PA
    no, it wouldn't cause that issue. Sounds like a giant vacuum leak.
    could have possibly installed your MAF backwards if you have a aftermarket turbo inlet intake setup?
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Sep 13 2014
    somewhere
    Quote Originally Posted by Dan[FN]6262 View Post
    everyone told me my car had a vacuum leak, other than like 1 person, who said to atleast try a TBA first off, Tried it, It was a TBA, same symptoms :) ^^^also it could be the MAF being backwards.
    Senior Member Two Rings PsorianoPre99A4's Avatar
    Dec 13 2015
    B8.5%20AR%2014%27%20P %20
    PNW
    Quote Originally Posted by Radskull1 View Post
    lol When I installed a new TIP and Intake set up, my car was doing this when I installed the MAF backwards
    Jun 22 2015
    Livonia, New York
    Well that 1% of uncertainty I had = me forgetting to hook up the charge pipe... Everything is back together and running properly... Thanks for the replies
    Sep 12 2008
    South Central PA
    there was your giant ass vacuum leak. LOL
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
