Well as some of you may know Ive been having fueling issues with my car and the problem was narrowed down to a faulty fuel pump.
I got my new one installed today and decided to see what was going on with the old one, Here are the results:
I cut around the base of the pump to drop the base and the impeller out, to my surprise, the impeller looked fine. I was shocked for a second because I thought for sure the impeller was what caused my problem.
Continued to disassemble and right when I got to the electric motor, I found my problem:
Inside this thing is where the broken magnet was:
Looks like the magnet to the electric motor cracked in half and sent all the shards through my fuel system.
I believe the debris from the magnet ripped a hole in my fuel filter and the FPR and made its way back through the fuel system back to the tank. There was a bunch of the debris in the bottom of the tank
I've flushed all my lines and siphoned out my tank, hoping my injectors are still okay. Still waiting on my new fuel filter to come in so I can start her back up.
