So i've been hunting for the cause of a rough idle for over a year now. I have a B6 A4 1.8 with apr 1+ that is driving me completely crazy looking for the cause of this rough idle. I've replaced all the check valves, replaced most of the crankcase vent system, vacuum lines, coil packs, spark plugs, combi valve, pancake valve, and probably more that I'm forgetting. The rough idle isn't really that bad, more annoying then anything. Basically when the car is in idle the engine shakes the entire car, more of a vibration than a shake. The vacuum will sit around 16 in, but will drop to 23 in when at speed and not on the throttle. My B5 sits at 20 at idle and 23 at speed which makes me think there is a vacuum leak but I cant for the life of me find it. I've tried boost leak testing it with a air compressor, and sprayed brake cleaner when the engine is running to see if it revs up both of which returned zero results. Any thoughts here guys?
