Results 1 to 11 of 11
    Active Member Four Rings
    Jul 17 2004
    ARD 2.7T Garrett Turbo Kit
    This is an ARD 2.7T Garrett Turbo Kit for sale with approximately 15k miles. All parts are in excellent condition.
    Asking $3500.
    The kit comes with:
    - ARD Tubular V-Band Manifolds
    - ARD 3'' V-Band Downpipes for External Wastegates
    - GT28RS Exhaust Housings with Welded Internal Wastegate Flap and V-Band Adapter (*CHRA/Rotating Assembly and Compressor Side not included*)
    - Two (2) TiAL V44 Wastegates
    - ARD GT Aluminum Inlet Pipe Kit
    Here is the full description of the kit:
    ARD GT TUBULAR MANIFOLDS
    The ARD GT Tubular Manifolds feature thick-gauge schedule-10 T304 stainless steel tubing for superb physical properties, welding characteristics and resistance to corrosion. Constructed with masterful TIG welding and high precision tooling, each set of ARD GT Tubular Manifolds is fabricated using machined jigs and fixtures to assure each set is identical. After considerable research and development, ARD created a low-turbulence merge collector, allowing exhaust gasses to flow into the turbine housing at tremendous velocities. In turn, turbocharger spool and response is maximized. A solid manifold flange is machined flat, creating a leak-proof seal to the turbine housing. The V-Band flange enables a quick install of the TiAL V44 wastegates, while welded EGT bungs provide OEM fitment.
    ARD 3 INCH GT DOWNPIPES
    Exhaust gasses flow through enormous three inch downpipes designed for use with TiAL V44 external wastegates. Fabricated with 304 stainless steel and meticulous TIG welding, the ARD GT downpipes are engineered with precision. The result is fast and responsive turbocharger spool up, low exhaust backpressure, and most importantly, a sonorous exhaust note to complete an exhilarating driving experience. To guarantee a leak-free seal, the ARD GT Downpipes are flanged with V-Band. This allows for easy installation and maximum versatility.
    TIAL V44 EXTERNAL WASTEGATES
    The ARD 2.7T GT Kit delivers a massive volume of air to the 2.7T engine. The need for a properly matched wastegate configuration is critical to keeping up with the demands of the turbo system and extracting the ultimate performance. After months of painstaking research and design, ARD has squeezed a pair of massive TiAL 44mm external wastegates into the tight confines of the 2.7T engine bay. The result is unparalleled boost stability and response. The TiAL V44 wastegates offer great versatility, allowing the user to easily set boost pressure. The wastegate tubes are re-routed back into the downpipes to minimize sound and retain the V-Band assembly. This ensures all connections have a perfect air-tight seal.
    ARD GT INLET PIPES
    ARD GT Inlet Pipes are designed with high-quality aluminum and fabricated in-house with a state-of-the-art mandrel bender. This ensures each set is manufactured consistently. ARD GT Inlet Pipes fitment is O.E., with a slip-fit over the compressor housing. To accommodate the huge volume of air demanded by Garrett Turbochargers, ARD GT Inlet Pipes have been developed with a much larger diameter than factory. Exceptional attention to detail contributes to the crisp throttle response of the ARD 2.7T GT Kit.
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Jul 17 2004
    Still available for sale
    Alex
    Senior Member Two Rings phukwatyaherd's Avatar
    Jul 06 2011
    2001 Audi S4 (track car)
    Clifton Heights, PA (Philly)
    FYI those aren't V-band manifolds, they have T-3 flanges. ARD actually sells their updated GT Parts kit new for $2500 (which is essentially what this is). That's a no less high quality of a kit than the updated setup they make now, I'd just suggest re-evaluating your asking price.
    Jul 17 2004
    Quote Originally Posted by phukwatyaherd View Post
    This includes two TiAL V44 wastegates and downpipes that have been routed for recirculating the wastegate exhaust internally (as opposed to screamer pipes). This also includes GT28RS hot sides with internal wastegate flaps welded shut. Something to consider with this price - and also, I am flexible with pricing as all offers are welcome!
    FYI - this was the first production ARD Kit. I was close friends with the fabricator and actually built the website you linked to. I'm very familiar with the original kit and how the kit has changed over the years :)
    Jul 17 2004
    This is the kit in action on low boost and pump gas (93):
    Apr 07 2011
    Home of the mighty beaver
    wow! blast from the past!
    Jul 17 2004
    bump - open to offers.
    Alex
    May 14 2012
    new jersey
    The v bands he talks about are for the wastegates to attach to not the turbo. Look at the pictures. Glws
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    $3500 for a bunch of used piping w/ no turbos?
    Jul 17 2004
    Bump
    Alex
    Jul 05 2015
    Still available?
