Results 1 to 4 of 4
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    Washer Fluid Reservoir Leak
    There is a leak somewhere in the reservoir or the connection between the fill tube and the reservoir. It's bad enough that it keeps the fluid level low enough that the low fluid light illuminates on the DIS and it's annoying me. I seldom use my washer fluid and wouldn't really care but for the warning light.
    How do I access the reservoir? Is it located behind the wheel well on the driver side? Do I remove the liner to get to it or can it be accessed from the engine bay?
    Is there a way to permanently disable the warning via VAG-com?
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    Veteran Member Three Rings ColtS5's Avatar
    Aug 18 2013
    2022 Kia Telluride, 2024 Jeep Grand Cherokee, 2018 Porsche Cayman S
    Indianapolis
    I have replaced the level sensor, and yes, if you remove the inner liner, you have good access of the reservoir. You should be able to check the connection at the bottom, the sensor and pump.
    Mar 01 2010
    Saskatchewan
    Quote Originally Posted by ColtS5 View Post
    Thank you!
    Mar 01 2010
    Saskatchewan
    I discovered last night that the DIS warning can be disabled using VAGcom. In Cent electric 09 and using the long coding helper there is a washer fluid sensor installed bite that can be disabled. Doesn't fix my leaking tank but does get rid of the annoying warning!
