Results 1 to 3 of 3
    Established Member Two Rings TylerG's Avatar
    Apr 03 2013
    United States
    Had 7 codes come up on a scan, wondering what you guys think?
    Address 01: Engine Labels: 06H-907-115-CAB.clb
    Control Module Part Number: 8K2 907 115 AL HW: 8K2 907 115 D
    Component and/or Version: 2.0l R4/4V TF H16 0001
    Software Coding: 0104010A190F0160
    Work Shop Code: WSC 26131 444 100868
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 (AU48)
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 79F9B25EF865ACF639-802C
    7 Faults Found:
    4483 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    4629 - ECM Power Relay Load Circuit
    P068A 00 [032] - Opens Too Early
    Freeze Frame:
    5646 - Leak in Air Intake System
    P2279 00 [096] - -
    Freeze Frame:
    2838 - Fuel Rail/System Pressure
    P0087 00 [096] - Too Low
    Freeze Frame:
    5671 - Boost Pressure Regulation
    P0299 00 [104] - Control Range Not Reached
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 116325 km
    Date: 2016.06.21
    Time: 18:39:59
    4105 - Bank 1; System too Lean at Idle
    P2187 00 [096] - -
    Freeze Frame:
    4201 - Fuel Level too Low
    P1250 00 [096] - -
    Freeze Frame:
    2010 Ibis White Audi A4 B8 Quattro Premium+ S-Line w/ Nav
    Jul 16 2008
    Finland
    What I think every time: Clear the DTCs and see if they come back. If the car works normally and the codes don't return, carry on driving! if a code comes back or the car is no working as it should, then it's worth investigating.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Feb 13 2004
    Silicon Valley, CA
    You already have a thread on this from yesterday
    http://www.audizine.com/forum/showth...you-guys-think
    This thread is now closed
    Kevin - Moderator, Audizine
