Originally Posted by
HereInOhio
Yep thats it. I looked for an hour last night but browsed so much studf I couldnt find it. I think Orilyes and Advanced Audo have some. Now as far as knowing every model they fit I do not. Some leg work on the guy needing the repair will be needed. Take the old nipple or new pump (if not installed) and try them out. If you cant get the nipple out and the new pump is installed I would buy all of the ones in that size range and return the extras. Hopefully you dont live too far away from the parts stores.
Hey man. Thank you for taking your time to help me out.
I went to NAPA and this older lady that worked there knew what the hell she was talking about. She helped me pick out the correct fittings and gave me a game plan to fix it.
I'm going to use a heat gun to heat the pressurized line going to the fuel pump to the fuel filter. I'll see if I can remove the old fitting. If that doesn't work, then I'll just cut the hose behind the fitting.
Either way, I'm going to jam in my own fitting and use the metal crimp to clamp down on the line to hopefully prevent leaks.
The fitting she found me is an EXACT fit and feels better than the OEM piece. (And is a much easier fitting to remove)
I also bought the quick connect kit for the hose. If I need to extend any hoses, I'll use the house from this kit. (I'm not using the fitting off this one)
I got another barb fitting just in case I need a smaller one.
