Results 1 to 7 of 7
    Aug 26 2011
    Louisville, KY
    Looking for some help diagnosing a Tiptronic issue
    I've read and googled and read and googled, and I'm more confused now than when I started. I'm hoping someone with some experience might be able to help.
    Car in question is a 2006 2.0T/Quattro/Tiptronic with 186.5k miles on it.
    Driving home from vacation last weekend I got some "shuddering" on the highway once the car got good and hot. It felt exactly like when a coil goes bad. Sudden jumps, or "kicks" form the driveline, with the only noticeable difference being the tach was jumping up slightly in this case, where a bad coil has the tach falling. I've continued driving around town on short trips all week and had no more of the symptoms. Monday night on the way home from a further destination (~45min drive) the car completely lost it's mind. The PRDNS is completely lit up (pic below), and it acts as though the car is stuck in perhaps 3rd or 4th gear with no Torque Convertor lockup at all. From what I've read this is "Limp Mode" and usually has to do with the transmission not getting good input, or not being able to control the outputs properly. I was able to limp the car home (~25mi) this way by avoiding most stops, and cruising on the expressway trying as best I could to not cause traffic problems.
    Here's a picture of the instrument cluster taken after it happened:
    I scanned the trans controller with VAG-COM and got these codes. I cleared those and tried to drive the car again. Didn't even get out of the driveway before it broke itself again.
    Code:
                    Address 02: Auto Trans       Labels: 09L-927-760.lbl
    Control Module Part Number: 8E1 910 156 C    HW: 09L 927 156 B
      Component and/or Version: AG6 09L 2.0TFSI USA 0030
               Software Coding: 0000002
                Work Shop Code: WSC 06335 000 00000
                          VCID: 275D1D1E964D1926F59-8072
    2 Faults Found:
    001814 - Transmission Input Speed Sensor (G182)
                   P0716 - 001 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01100001
                        Fault Priority: 0
                        Fault Frequency: 16
                        Reset counter: 40
                        Mileage: 300349 km
                        Time Indication: 0
                        Date: 2064.00.00
                        Time: 00:00:00
                 Freeze Frame:
                        RPM: 2944 /min
                        RPM: 0 /min
                        RPM: 3232 /min
                        (no units): 13.0
                        (no units): 57.0
                        Temperature: 74.0°C
                        T.B. Angle: 43.5°
    001543 - Control Module Performance Implausible
                   P0607 - 000 -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 300349 km
                        Time Indication: 0
                        Date: 2064.00.00
                        Time: 00:00:00
    After another try I did a full scan and got these codes. I cleared these as well, but no help. Nothing overly concerning that I can see. Looks like I have an EVAP leak (AGAIN) to deal with, and the radio/bluetooth module isn't working quite right, but otherwise nothing that would cause the transmission to lose it's mind like this.
    Code:
    Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
              67 69 75 76 77
    VIN: WAUDF78EX6A093408   Mileage: 300350km/186628miles
    Address 01: Engine        Labels: 06F-907-115-AXX.lbl
       Part No SW: 8E0 910 115 M    HW: 8E0 907 115 D
       Component: 2.0l R4/4V TFSI     0070
       Revision: --H10---    Serial number:
       Coding: 0104010A190F0120
       Shop #: WSC 07437 444 67512
       VCID: 2B55E12E8AA53D46111-807E
    2 Faults Found:
    001089 - EVAP Emission Control Sys
                   P0441 - 002 - Incorrect Flow
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 300354 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 1094 /min
                        Load: 38.4 %
                        Speed: 0.0 km/h
                        Temperature: 98.0°C
                        Temperature: 39.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.462 V
    005668 - MIL Request Signal Active (Check TCM for errors too!)
                   P1624 - 008 -
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 300357 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 1082 /min
                        Load: 26.7 %
                        Speed: 0.0 km/h
                        Temperature: 98.0°C
                        Temperature: 43.0°C
                        Voltage: 13.208 V
    Readiness: 0000 0000
       Part No SW: 8E1 910 156 C    HW: 09L 927 156 B
       Component: AG6 09L 2.0TFSI USA 0030
       Revision: --H01---    Serial number:        4078864
       Coding: 0000002
       Shop #: WSC 06335 000 00000
    No fault code found.
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
       Component: ESP8 quattro    H05 0120
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0004528
       Shop #: WSC 00493 128 20329
       VCID: 29591B2680592F56E3D-807C
    Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2832
       Coding: 00000
       Shop #: WSC 00000
       VCID: 6DD12F362731F3764F5-517A
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  ECE 0504
       Coding: 01021
       Shop #: WSC 06335
       VCID: 3B75D16E29C5ADC6811-4B36
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H11 3540
       Revision: 91H1135    Serial number: 0036N000VKKH
       Coding: 0032607
       VCID: 3C77D2727FCBAAFE88B-8069
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 002 0070
       Subsystem 2 - Serial number: 34K94
       Subsystem 3 - Serial number: 0001.01.000000200000000000˙†63
       Subsystem 4 - Serial number: 000000˙†6332DRB40215CE18Q˙†63
       Subsystem 5 - Serial number: 5CE18Q˙†6342DRB402044FB1L˙†63
       Subsystem 6 - Serial number: 44FB1L˙†6352ARB40090108CC˙†63
       Subsystem 7 - Serial number: 0108CC˙†6362ARB4008F5EAC4˙†63
       Subsystem 8 - Serial number: F5EAC4˙†63729RB400A8E128Q˙†63
       Subsystem 9 - Serial number: 8E128Q˙†63829RB400A8EB75$˙
       Subsystem 10 - Serial number: 8EB75$˙
    1 Fault Found:
    00532 - Supply Voltage B+
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 2
                        Fault Frequency: 25
                        Reset counter: 39
                        Time Indication: 0
                        Date: 2064.00.00
                        Time: 00:00:00
    Address 16: Steering wheel        Labels: 8E0-953-549.lbl
       Part No: 8E0 953 549 R
       Component: Lenksįulenmodul     1002
       Coding: 04041
       Shop #: WSC 03332
       VCID: 428BAC8A4E2FDC0EC27-4B36
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 982 F    HW: 8E0 920 982 F
       Component: KOMBI+WFS 4     H12 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0023001
       Shop #: WSC 03213 444 84058
       VCID: 3169F346AB8957962BD-517A
    1 Fault Found:
    01304 - Radio
                004 - No Signal/Communication - Intermittent
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023001
       VCID: 3169F346AB8957962BD-515E
    1 Fault Found:
    01304 - Radio
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       Shop #: WSC 00000
       VCID: F1E9B346BB099796EBD-4B36
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 BT
       Component: Komfortgerįt T7B    3332
       Coding: 11896
       Shop #: WSC 06335
       VCID: 8407EA9294BB923E30B-4B36
       Subsystem 1 - Part No: 8E1959801G
       Component: Tõrsteuer.FS BRM 0406
       Subsystem 2 - Part No: 8E1959802E
       Component: Tõrsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8E0959801E
       Component: Tõrsteuer.HL BRM 0506
       Subsystem 4 - Part No: 8E0959802A
       Component: Tõrsteuer.HR BRM 0205
    4 Faults Found:
    01368 - Alarm triggered by Luggage Compartment Switch
                35-00 - -
    01369 - Alarm triggered by Hood Switch
                35-00 - -
    01374 - Alarm triggered by Terminal 15
                35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
                35-00 - -
    Address 55: Xenon Range        Labels: 4F0-910-357.lbl
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Revision: 00000001    Serial number:
       Coding: 0000019
       VCID: 2643101A9147002ECEF-8073
       Subsystem 1 - Part No: 8E0 941 329
       Component: AFS-Modul links H03 0020
       Subsystem 2 - Part No: 8E0 941 329
       Component: AFS-Modul rechtsH03 0020
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 8E0 035 195 H
       Component: symphony II PM6    0460
       Coding: 01065
       Shop #: WSC 72960
       VCID: 2C57E232DCAB3A7E18B-5106
    2 Faults Found:
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
                29-10 - Short to Ground - Intermittent
                36-00 - Open Circuit
    Address 77: Telephone        Labels: 8P0-862-335.lbl
       Part No SW: 8P0 862 335 T    HW: 8P0 862 335 T
       Component: FSE_256x BT     H34 0550
       Revision: 00000000    Serial number: 00000005018951
       Coding: 0001677
       Shop #: WSC 03332 444 80734
       VCID: 479DBD9E350DF926159-517A
    1 Fault Found:
    00003 - Control Module
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 15
    End   ---------------------------------------------------------------------
    Of course it's been less than 30 days since I mailed in the final payment. I was hoping to drive this car for a few more years, but don't want to spend thousands of dollars on a car that is arguably not worth more than about $3,500 in a good market. I like the car and don't mind putting some money in it, but I won't sink a ton into it at this point.
    If there are things that I can check like wiring, and sensors, and other things of that nature, then I'm all for it. I just have no idea how to even find these sensors, much less how to check them. I'm savvy with a set of tools and a multi-meter, and don't mind getting dirty, I just have no idea where to start on this one.
    Any help would be greatly appreciated!
    Oct 24 2015
    Perth, WA
    Electrical issue. Check all fuses and relays. Unhook the battery, discharge the leads together for 15 minutes and rehook the battery. Scan again.
    - - - Updated - - -
    Also check there is no water in the ECU box.
    My respray thread
    Aug 26 2011
    Louisville, KY
    Discharge the leads togethor? You mean hook them togethor to drain capacitors and such?
    Does this car have a separate TCM and PCM or are they integrated into one unit like a GM vehicle?
    Thanks for the help. I'll go through the car tonight and post back with what I find.
    Aug 26 2011
    Louisville, KY
    OK, Spent some time with the car tonight.
    Disconnected the battery for 20 or so minutes while I did other things. Checked and cleaned the ECM compartment. It's nice and clean, looks like it's never been wet in there. Checked every fuse and relay that I could find inside the box. All look/smell ok, and all fuses were in great condition, not so much as corrosion on the terminals. Checked the plug going to the transmission. All the wires there look to be in good shape, no damage to connector, no signs of water intrusion or other such damage. I have pics of everything checked below. I reconnected the battery, and pulled a full scan from VAG-COM again. Found the same P0717 code again from the transmission.
    Here's the ECM compartment:
    Here's the plug and harness under the car
    Here's the fault code log from VAG-COM
    Code:
    VCDS Version: Release 12.12.0
    Data version: 20130910
    Tuesday,01,October,2013,17:19:12:40973
              67 69 75 76 77
    VIN: WAUDF78EX6A093408   Mileage: 300390km/186653miles
    1 Fault Found:
    012555 - Low Pressure Fuel regulation
                   P310B - 008 - Fuel Pressure Outside Specification - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 300399 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 989 /min
                        Load: 68.6 %
                        Speed: 2.0 km/h
                        Temperature: 26.0°C
                        Temperature: 30.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.970 V
    Readiness: 0000 0100
       Coding: 0000002
    1 Fault Found:
    001815 - Transmission Input Speed Sensor (G182)
                   P0717 - 000 - No Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00110000
                        Fault Priority: 0
                        Fault Frequency: 19
                        Reset counter: 40
                        Mileage: 300361 km
                        Time Indication: 0
                        Date: 2064.00.00
                        Time: 00:00:00
                 Freeze Frame:
                        RPM: 1088 /min
                        RPM: 0 /min
                        RPM: 0 /min
                        (no units): 1.0
                        (no units): 34.0
                        Temperature: 93.0°C
                        T.B. Angle: 0.0°
       Coding: 0004528
       Coding: 00000
       Shop #: WSC 00000
       VCID: 6DD12F362731F3764F5-5198
       Coding: 01021
       Shop #: WSC 06335
       VCID: 3B75D16E29C5ADC6811-4B50
       Coding: 0032607
       Coding: 04041
       Shop #: WSC 03332
       Coding: 0023001
       VCID: 3169F346AB8957962BD-5198
       Coding: 0023001
       Coding: 00002
       Shop #: WSC 00000
       VCID: F1E9B346BB099796EBD-4B50
       Coding: 11896
       Shop #: WSC 06335
       VCID: 8407EA9294BB923E30B-4B50
       Coding: 0000019
       Coding: 01065
       Shop #: WSC 72960
       VCID: 2C57E232DCAB3A7E18B-50E8
    2 Faults Found:
       Coding: 0001677
    1 Fault Found:
                014 - Defective
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 15
    NOW.....Here's where it gets fun. The car is working perfectly again. Drove it up/down the block, then out to the gas station and back (didn't want to stray to far from home). Overall it performed as well as it ever has. Shifts are firm, but not harsh. All modes work as expected, and there was no surging/stumbling. It did great! What the hell car?!?!?!
    The only thing I can think of that ties the problems together is heat. The trans seems to act just fine when cool, but once really warmed up (notice the freeze frame data has 93deg C as when the error code was logged) the problems appear. Kind of hard to test this tonight as it's a good 25deg F cooler outside than it was on Monday when it fully went into limp mode (96 then, 71 tonight). Not sure how else to test other than to keep the VAG-COM machine in the car with me, and keep driving the thing around until it happens again, then try to get a datalog of what is happening.
    Now, on to the log, and the research I've found from that. Looks like the P0717 code points me to the G182 sensor. This sensor appears to be inside the transmission on the ZF5HP19A (pics from tdiclub.com show it above the valve body), and I would assume that the ZF6HP19A would be similar. I can't find this sensor for sale anywhere. I don't really have a problem pulling the pan and replacing the fluid (probably needs it anyway), but I need to replacement part before I can get too enthused about replacing it. I'm going to call the dealership in the morning, but I have a suspicion that they won't be able to get ahold of the transmission internal pieces due to the replace instead of refurb/rebuild mentality of most dealerships now days. Anyone have any input/info on where I can find one of these sensors?
    Anyone have any other thoughts?
    Oct 24 2015
    Perth, WA
    My respray thread
    Aug 26 2011
    Louisville, KY
    I saw that picture as well. That was noted in a TDi thread about a ZF5HP trans. I'm sure the ZF6HP is similar, but it's hard to say with these transmissions. Looks like that DIY is for a CVT, my trans doesn't look like that one at all.
    Car has been working flawlessly all week. I've found it's replacement, and will most likely be putting it up for sale here soon. Thanks for the help!
    Jun 19 2015
    Parma, Ohio
    From what I gathered the TCM is part of the ECM on a 2.0t. If you take out the engine you have to unplug the main connector for the trans b/c it's part of the engine harness. And it dose not plug in to another harness any where else other than the injector harness. If you find a sensor take the part number off the back and type it in on Google. Works pretty well with a decent amount of b7 parts. My guess is I'd shoot for that trans out put speed sensor. You can take it off and check it, hook your volt meter up and set it to resistance and spin a bolt head in front of the sensor and you will watch the sensor work as it goes past a flat it will drop off and search and when it passes a corner it will show a change in resistance. Or pick it up and wave it past metal and you can watch the same thing. If that checks out good check the wireing between the sensor and the trans main plug. Then work your way up towards the ECU. Use a test light to check wireing if you need further questions about checking wiring I'll check back. If you do it wrong or don't know what your doing you will over look something thinking it's good and that was really your problem. Or fry something expensive.
