Results 1 to 9 of 9
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    stage 3 cyl2 misfire
    What could you tell from this picture?
    16686 - Cylinder 2
    P0302 - 35-00 - Misfire Detected
    Jun 10 2013
    United States
    What is freeze frame data? Plug looks healthy to me. Would help to see it from the top as well.
    Senior Member Two Rings BlackOnBlackA6's Avatar
    May 24 2005
    '01 A6 Avant 2.8
    Fairfax, VA
    Threads?
    May 24 2005
    '01 A6 Avant 2.8
    Fairfax, VA
    Question... What type of tool unscrews and pulls out spark plugs. Mine keep falling back into the 'well'.
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by glennda5id View Post
    not logged yet, which channels to log in vag-com?
    drive drives great, except some light jerking at WOT.
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Quote Originally Posted by BlackOnBlackA6 View Post
    Spark plug socket with rubber grommet.
    Sent from my SM-G930T using Tapatalk
    Jun 10 2013
    United States
    Quote Originally Posted by V1nny View Post
    If you are using a registered version of VCDS then there is an option to show freeze frame data. That should show you all other sensor values when the misfire occurred. Freeze Frame is an OBDII thing, but VCDS supports it.
    Anyways, your plug looks good, I would try moving the #2 coil pack to a different cylinder and see if the misfire moves with it. If in doubt about the plug you could do a separate swap with another cylinder and see if it moves.
    May 20 2010
    Quote Originally Posted by Royal769sr View Post
    You can also use the coil pack to "grip" the spark plug after it's been unthreaded all the way. I did this when I did not have a spark plug socket handy.
    May 22 2013
    Las Vegas, NV
    Nice one
