Hey everyone, Thanks for your time! I have a 04 B6 S4(4.2) with a 6 speed manual 01E for parts and my 04 2.7T Allroads tiptronic is acting up so im thinking about doing the 01E swap from the B6 to the Allroad. ive done some research but could not find much info on the 01E swap on Allroads. found mostly about A4 and A6s wich is pretty much the same. from what i see, it seems like it can be done without major issues but i couldnt find info on the clutch pedal cluster and driveshaft and which rear end to use. Can anyone confirm if i can use the B6 pedal cluster on my Allroad to add the clutch pedal? can i use the clutch disk, pressure plate and flywheel from the B6 4.2 in the Allroad? if not, which clutch kit should i use? and i believe the B6 S4 has 4.11 rear end and im not sure what i have on the Allroad so what would be the better one to use. i have both entire cars so i can get whatever parts i need from the B6 S4 to use on the ALLroad, but trying to see about what im getting into before i get started. Any info on this will be greatly appreciated. my Allroad is a 2004 2.7T tiptronic. my Parts car is a 04 S4 4.2 6 speed manual. Thanks in advance!!
