Results 1 to 24 of 24
Thread: Is this normal
    Established Member Two Rings Jg3's Avatar
    Jun 11 2015
    2005 A4 B6 3.0 cabriolet
    SGV
    Is this normal
    Why is my MAF sensor going crazy and is specified boost and actual supposed to be that much apart?
    Sent from my SM-T237P using Tapatalk
    May 20 2010
    Dirty MAF? Vacuum leak? Wastegate settings? Busted DV (which would then throw a code)?
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Quote Originally Posted by Jg3 View Post
    need more info, logs, CEL, ect...
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
    Jun 11 2015
    SGV
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Sunday,12,June,2016,19:22:24:62939
    Chassis Type: FL (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
    72 77
    VIN: WAUFFAFL3CN013555 Mileage: 212000km/131730miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (0-----CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H20 0002
    Revision: E1H20---
    Coding: 0104010A290F0160
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
    ROD: EV_ECM20TFS0118K2907115AG.rod
    VCID: 74E73A5BDF4EF4BE80B-8021
    1 Fault Found:
    7663 - Boost Pressure Control Valve (N249)
    P2261 00 [100] - Mechanical Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 211993 km
    Date: 2016.06.12
    Time: 18:58:49
    Readiness: 0100 0101
    Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
    Part No SW: 8K0 927 158 S HW: 0BK 927 156 R
    Component: 0BK 20TFSIUSA H17 1003
    Revision: --H17---
    Coding: 000002
    ASAM Dataset: EV_TCMAL551211 002018
    ROD: EV_TCMAL551211_AU48.rod
    VCID: 4683B093F952362EEEF-8013
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 1D0D18
    Shop #: WSC 02391 823 56573
    VCID: 820BEC831DFA4A0E027-80D7
    2 Faults Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 207
    Mileage: 210920 km
    Time Indication: 0
    Date: 2016.06.05
    Time: 13:48:16
    Freeze Frame:
    Hex Value: 0x4000
    Hex Value: 0x4006
    Hex Value: 0x1226
    Hex Value: 0x46AC
    Hex Value: 0x00FF
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 207
    Mileage: 210920 km
    Time Indication: 0
    Date: 2016.06.05
    Time: 13:48:17
    Freeze Frame:
    Hex Value: 0x4400
    Hex Value: 0x6206
    Hex Value: 0x1232
    Hex Value: 0x02AD
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
    Component: BCM2 2.0 H05 0435
    Revision: 00002001
    Coding: 0D0100
    Shop #: WSC 02399 823 56573
    VCID: 77FD0D57C6389FA6A59-8022
    Subsystem 1 - Part No SW: 8T0 959 754 G HW: 8T0 959 754 G
    Component: FBSAUDIB8 IDG H61 0072
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
    Component: KLIMA 3 ZONEN H08 0180
    Revision: C1000000 Serial number: 01211020111576
    Coding: 64002000
    VCID: 800FE68B13F6581E143-80D5
    Address 09: Cent. Elect.
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
    Component: AirbagVW-AU10 H44 0610
    Serial number: 003GLD0P685B
    Coding: 303837354230303030304A55304C384B3053
    Shop #: WSC 02135 785 00200
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 4581B79FC4543D36E75-8010
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
    Component: BF-Gewichtss. H02 0040
    Serial number: 5810000R1100005TY1
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME6575425BI
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME63550A1AE
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME1F5F2F42-
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME1161155CA
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME14632B62Y
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME12614746V
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H17 0014
    Revision: -------- Serial number: 90372KJH001G7
    Coding: 000016
    VCID: 3D71DF7FA48475F6BF5-8068
    Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 950 H HW: 8K0 920 950 H
    Component: KOMBIINSTR. H20 0258
    Revision: 00300000 Serial number: EIL61ENAC
    Coding: 8B1609000300D705020000
    VCID: 3467FA5B97CEB4BE40B-8061
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AF HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0120
    Revision: GB901054 Serial number: 5400G11A118666
    Coding: 00C303
    VCID: 8501F79F0CD47D36275-80D0
    Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
    Component: J367-BDM H07 0170
    Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
    Part No SW: 8T0 035 785 A HW: 8T0 035 785
    Component: SG ext.Player H08 0290
    Revision: 00000000
    Coding: 020302
    VCID: 3979CB6FB0AC49D693D-806C
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0076
    Revision: AA000000 Serial number: 00000016751289
    Coding: 00581B00000000000000
    VCID: 3B75D167BA907BC6811-806E
    1 Fault Found:
    03331 - Motor for Backrest Angle Adjustment
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 181499 km
    Time Indication: 0
    Date: 2015.12.23
    Time: 21:04:05
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
    Component: TSG FA H08 1501
    Coding: 011C13204E00410001
    VCID: 53A599C732009386791-8006
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0160984479
    Coding: 0106023A00FA440580B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
    Component: GTO BF H01 0070
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J245 PS050 H08 0043
    Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
    Part No SW: 8T0 035 223 AH HW: 8T0 035 223
    Component: DSP STD H07 0230
    Revision: S2200000
    Coding: 0203010102
    VCID: 74E73A5BD74EF4BE80B-8021
    1 Fault Found:
    02247 - Subwoofer (R148/R157)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 28
    Reset counter: 185
    Mileage: 204350 km
    Time Indication: 0
    Date: 2016.04.22
    Time: 20:47:30
    Freeze Frame:
    Voltage: 12.80 V
    Temperature: 37.0°C
    Bin. Bits: 00000000
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1501
    VCID: 52AB9CC30D1A9A8E727-8007
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 20000000133973
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 207
    Mileage: 210920 km
    Time Indication: 0
    Date: 2016.06.05
    Time: 13:48:17
    Freeze Frame:
    Voltage: 13.90 V
    Count: 58
    Speed: 68.0 km/h
    Hex Value: 0x0260
    Hex Value: 0x0004
    Hex Value: 0x0101
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
    Component: ....LWR12.... H02 0010
    Serial number: 111020-0002-126
    Coding: 1171A41010020400
    Shop #: WSC 02145 785 00200
    ASAM Dataset: EV_HeadlRegulBasic 005001
    ROD: EV_HeadlRegulBasic.rod
    VCID: 2D51EF3F7CE4E5760F5-8078
    Address 56: Radio (J003) Labels: None
    Part No SW: 8Q1 035 183 R HW: =T1 035 1=6 R
    Component: Cjn3 Sirlus H56 0651
    Revision: 05000011 Serial number: APZ5Z6K1360644
    Coding: 040700020101850046D9070800
    Shop #: WSC 67927 821 56573
    VCID: 408FA68BD376181ED43-8015
    Subsystem 3 - Part No SW: 8Q0 919 606 F HW: 8Q0 919 606 F
    Component: Dlsplay %
    2 Faults Found:
    03157 - Functionality limited due to Communications Disruption
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    02635 - Tuner Not Enabled/Activated
    000 - -
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
    Component: TSG HL H06 1501
    Coding: 010C13204000210001
    VCID: 56A360D321F286AE9EF-8003
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Component: TSG HR H06 1501
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
    Component: FSE_256x BT H45 0660
    Revision: 00000000 Serial number: 00000005244469
    Coding: 0010370
    Shop #: WSC 02335 785 00200
    VCID: 3E73D87369826EEEA6F-806B
    End ---------------------------------------------------------------------
    Sent from my SM-G928V using Tapatalk
    Jun 11 2015
    SGV
    How do I clean maf?
    Jun 11 2015
    SGV
    Also do you think I could be getting those codes because i have a hks ssqv bov installed on intercooler hose and have stock dv blocked off?
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    This can cause ALLLLLL sorts of issues. Why would you install a BoV? Not sure if you realize this is a MAF fuel based engine, not a speed density (MAP) based fuel map. Allowing metered air to release without the computer knowing will cause all sorts of issue in regards to fueling. You need to use the DV.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Jun 11 2015
    SGV
    Quote Originally Posted by Allowencer View Post
    Even if it's recirculating?
    Jun 12 2013
    Not sure what you mean. You have the DV blocked off an a Blow Off Valve installed within the charge pipe correct? The Blow Off Valve goes to atmosphere, correct?
    Build Thread
    Jun 11 2015
    SGV
    Jun 26 2009
    Bremerton WA
    That BOV doesn't recirculate. The small line is the vacuum line that activates the valve and it depressurizes the charge pipe to atmosphere. Luckily loosing air and the ECU still feeding fuel will send you rich vs lean so not that bad. The stock DV due to its location on the turbo and that the ECU has far faster and better control that being vacuum based is likely causing the P2261 as the ECU likely sees a pressure spike as the intake isn't depressurizing as fast as it expects. With electronic throttle the ecu can see the sensor move and have the DV in motion depressurizing the turbo before the throttle can close and build the vacuum and operate a BOV.
    As for a MAF reading at idle 2.66g/s that stays steady and about 5.7g/s at 2000 RPM (no load high idle). Are your MAF readings steady and what values?
    VMR 710's, APR software, Eurocode HFC
    Jun 12 2013
    Yeah man, get rid of that. That's a BoV at the end of the charge circuit. This WILL cause you tons of problems. Why re-invent the wheel on this? You SHOULD be using the N75 valve and DV valve through the ECU. Not work against it.
    Build Thread
    Jun 11 2015
    SGV
    Because I've been thru 2 oem dv's and 1 GFB dv (which was worse than oem) as soon as I switch to tuning APR stage 1 I can hear the dv little by little do more flutter till it just ends up wearing down spring and staying open. So me not knowing I decided to try HKS SSQV and I love the sound and didn't notice any difference in performance but did get less mpg
    Jun 12 2013
    Were any of those OEM DV's the latest upgraded one? Have you tried a Pierburg?
    Forge, non-BoV would be your best stock upgrade if you wanted to go aftermarket. However, I'd recommend to stay with Pierburg.
    Build Thread
    Jun 11 2015
    SGV
    One was and it was a lil better than the first but still same thing happened
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Sounds like something abnormal is killing your DVs. I'd try to find the source of that first, or cut your losses and take a chance on the Forge, like Allowencer mentioned.
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    May 20 2010
    Many folks run OEM DVs and are higher than APR Stage 1. Agree that something else is killing your DVs, and you should look into solving that issue. Get rid of the BOV.
    Personally, I'm not a fan of Forge DVs because it gave me all sorts of issues on my car, but in this case, whatever works, since the current setup is obviously not.
    Jun 11 2015
    SGV
    On a Ko4?
    Jun 11 2015
    SGV
    What is the normal boost psi supposed to be?
    May 20 2010
    On a Ko4?
    Sorry, I misinterpreted your earlier statement to read you were Stage 1. But yes, on a K04--that's what I run on my B7. I've boosted up to about 24 psi before, and haven't had any issues with the DV (Rev D on the piston version). Are you using the latest OEM piston style or diaphragm style? As soon as I went K04, I tore the diaphragm like it was nothing.
    Jun 11 2015
    SGV
    I have no DV right now i blocked it off and put in a HKS SSQV which I'm being told was bad idea
    May 20 2010
    Yes, but you said you kept blowing out the stock ones. I thought that meant before this setup. If you can revert, please do, and see if that fixes your issues.
    Jun 11 2015
    SGV
    Yeah I'm gonna try it
    Jun 12 2013
    I have the Pierburg and am running 23-25 PSI on my FT
    Build Thread
