    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    Strange Brake Pedal
    Halo,
    My brake pedal is acting strange, it applies this sort of electrical resistance, like it's getting snagged on sometime, for a moment or two, until it lets go again and everything is normal.
    This happens probably 11 times per hour of driving.
    Ideas?
    ~ ea
    1999 A4 FWD AEB 1.8T ~ Atlas
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Is it only at low speeds? Does your ABS light ever flash or stay on?
    My guess is either:
    a) tone ring on one of the driveshafts is damaged
    b) ABS sensor is damaged
    c) ABS sensor is sticking out too far from the tone ring (would just need to be pushed in a little)
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Apr 22 2014
    Aptos, CA
    Only @ low speeds, yes.
    It does feel ABS related.
    What is this Tone Ring?
    Veteran Member Three Rings pee quu's Avatar
    Jan 25 2009
    Oceanside, NY
    If I am not mistaken its the ring on the axle that the sensor reads. I had this sort of issue once and it turned out sensor for the driver side front wheel was too close to the ring. I put a washer around the sensor to pull it out a little and it was fine after that.
    2000 B5 A4 / C5 S6 V8 swap / B5 S4 driveline swap / PVW Nov 2016
    Apr 22 2014
    Aptos, CA
    alright, thanks.
